Primer versus Paint - Router Forums
 5Likes
post #1 of 22 (permalink) Old 07-18-2015, 09:47 PM Thread Starter
Default Primer versus Paint
Today I finished a utility shelf made with pine dimensional lumber. The bottom was screwed and glued to the sides. The screws were countersunk, and the screw holes were filled with Plastic Wood. For finish, I sprayed white primer.
The Plastic Wood-filled holes still show through the primer even though they are sanded perfectly smoothly. They are clearly visible even after two coats of primer. Is primer more translucent than paint? If I paint these, will the covered holes disappear?
Scotty: I can't change the law of physics! I've got to have 30 minutes!
patlaw is offline
post #2 of 22 (permalink) Old 07-18-2015, 09:59 PM
yes on the translucent...
if you are worried...
mix some wood glue w/ water (1:1) and hand paint the plastic wood w/ the mix...
post #3 of 22 (permalink) Old 07-18-2015, 10:01 PM Thread Starter
Good
{quote]if you are worried...
mix some wood glue w/ water (1:1) and hand paint the plastic wood w/ the mix...[/QUOTE]
I'm not worried, but I am curious. Why does this routine work?
patlaw is offline
post #4 of 22 (permalink) Old 07-18-2015, 10:11 PM
Originally Posted by patlaw View Post
Good
I'm not worried, but I am curious. Why does this routine work?[/QUOTE]
the plastic wood absorbed some of the primer or the primer didn't adhere really well because you sprayed... the glue mix is a premium sealer..
the kids used felt tips for their art work on the walls and trim..
primer/sealer/paint of several coats each and the art work is still bleeding through...
use the glue mix and and it will stop the bleed through in it's tracks...
MYB and Roy Drake like this.
post #5 of 22 (permalink) Old 07-18-2015, 10:25 PM Thread Starter
I'm going to use the mix you suggested. Out of curiosity, though, would spraying shellac on the wood first have helped?
patlaw is offline
post #6 of 22 (permalink) Old 07-18-2015, 10:32 PM
pigmented...
post #7 of 22 (permalink) Old 07-18-2015, 10:38 PM
Some of the wood fillers are very porous.The glue mix should seal them up. Some glues are very hard to sand though as they are somewhat rubbery so get it smooth while it's wet. I used to use the stuff that's thinned with toluene or laquer thinner.It's pretty crappy stuff. The best is Durham's. It's a dry powder that you mix with water. Once mixed you have maybe an hour to use it max. In many cases it dries harder than the wood you use it on.
drdenny1946 likes this.
post #8 of 22 (permalink) Old 07-18-2015, 10:46 PM
Rock Hard putty
Herb Stoops is online now
post #9 of 22 (permalink) Old 07-18-2015, 11:40 PM
Rock Hard...
post #10 of 22 (permalink) Old 07-19-2015, 12:43 AM
Yep. This stuff. And it's cheap. Durham's Rock Hard Water Putty
Latex Primer question JOAT The Finishing Touch 7 03-11-2013 07:13 AM
Paint over paint The Warthog The Finishing Touch 3 09-29-2011 12:55 AM
My Step-Back Cupboard Build rwyoung Project Plans and How To 53 11-13-2010 10:22 AM
Thinning out paint to soak in wood StormStrikes The Finishing Touch 3 08-18-2010 10:59 PM
