Removing Machine Marks From Boards - Router Forums
 4Likes
post #1 of 24 (permalink) Old 07-31-2015, 04:26 AM Thread Starter
Gaia's Avatar
First Name: Peter
Default Removing Machine Marks From Boards
Hi,
Removing planer ripple and any other machining marks from house door rails, stiles and wide raised panels.
Whats the way to go?
Thanks.
Gaia is offline
post #2 of 24 (permalink) Old 07-31-2015, 04:51 AM
Originally Posted by Gaia View Post
Hi,
Thanks.
control the snipe to start with...
smoothing plane and sanding to remove...
chas980 and firstmuller like this.
post #3 of 24 (permalink) Old 07-31-2015, 08:59 AM
PhilBa's Avatar
First Name: phil
Probably the best way to avoid snipe is to use a sacrificial piece of wood ahead and behind the actual one(s). Also, if you have multiple pieces, over lap them through the planer. So feed the lead in sacrifice, then your pieces, then the tail end sacrifice all in one uninterrupted stream.
Also, a scraper is a great tool to learn how to use. Done right, the surface can be smoother than sanding.
MT Stringer likes this.
PhilBa is offline
post #4 of 24 (permalink) Old 07-31-2015, 10:06 AM
If it`s your planer and you can slow it down that helps with the ripples. Otherwise it`s a lot of sanding or a combination like Stick suggested.
post #5 of 24 (permalink) Old 07-31-2015, 10:08 AM Thread Starter
Gaia's Avatar
First Name: Peter
Thanks for that Stick and Phil.
Using a smoothing plane, won't the shavings removed start to alter the dimensions of the work piece? Or on the original do I allow a couple of mm to allow for this?
I've been reading about palm random orbital sanders and the air powered type. Then using sand paper to remove any little squiggles left from that to get to the required finish?
Cheers.
Gaia is offline
post #6 of 24 (permalink) Old 07-31-2015, 10:15 AM
sanded, scraped or hand plane it's still material removed...
post #7 of 24 (permalink) Old 07-31-2015, 10:16 AM Thread Starter
Gaia's Avatar
First Name: Peter
and the planer with razor sharp knives and all properly set up
Gaia is offline
post #8 of 24 (permalink) Old 07-31-2015, 10:42 AM Thread Starter
Gaia's Avatar
First Name: Peter
I know little about planes, No 5, 6 etc. What size, type of smoothing plane would I be wanting for a door stile say 100mm wide x 40mm deep? Is a smoothing plane suitable for cleaning up the edge too? Just looking I've seen 22 inch long smoothing planes, that wouldn't do.
Thanks.
Gaia is offline
post #9 of 24 (permalink) Old 07-31-2015, 11:03 AM
Thanks.
Veritas® Low-Angle Smooth Plane - Lee Valley Tools
post #10 of 24 (permalink) Old 07-31-2015, 12:18 PM Thread Starter
Gaia's Avatar
First Name: Peter
Do you mean a continuous length of timber under the board I want to plane, extending out the front and rear of the board? Or are you saying just a short section under each end of the board, extending a bit from the ends of the board?
Thanks.
Gaia is offline
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 11:19 AM
Removing "marks-a-lot" marks Sancman Project Plans and How To 7 03-07-2014 04:14 PM
My new improved homemade router milling machine. Mark55 Table-mounted Routing 16 02-01-2013 05:42 PM
Pachinko Machine kp91 KP91's gallery 11 03-10-2012 10:15 PM
