Acrylic lacquer over shellac - Router Forums
 9Likes
post #1 of 19 (permalink) Old 08-17-2015, 02:23 PM Thread Starter
hankh's Avatar
Country: Israel
First Name: Hank
Default Acrylic lacquer over shellac
I finished coffee tables with shellac (flakes cut with alcohol). The tables are Indian rosewood and maple. I am thinking of adding a coat (or 2) of water-based acrylic lacquer to protect the finish. Will the lacquer bond adequately with the shellac? Is this a good idea or a terrible one?
Murtu01 and BIG OLD TIM like this.
hankh is offline
post #2 of 19 (permalink) Old 08-17-2015, 03:18 PM
Shellac is often used as a barrier between incompatible finishes so the chances are good. Try it on a test piece first Hank. Because shellac is dissolved in alcohol there is a good chance that if they are incompatible it will show right away.
post #3 of 19 (permalink) Old 08-17-2015, 03:33 PM
PhilBa's Avatar
First Name: phil
Yes, that will work just fine as long as you used dewaxed flakes.
TwoSkies57 likes this.
PhilBa is offline
post #4 of 19 (permalink) Old 08-17-2015, 05:08 PM
TwoSkies57's Avatar
EMPHASIS ON DEWAXED!!!!
Lacquers provide little in the way of protection.
Consider a good wipe on poly. Easy to apply, builds up nicely, dries much quicker than regular poly's (but not nearly as fast as lacquers) easy to touch up if needed available in all gloss's.
Nickp and PhilBa like this.
Skipper the Penguin
TwoSkies57 is offline
post #5 of 19 (permalink) Old 08-17-2015, 07:28 PM
PhilBa's Avatar
First Name: phil
I really like the minwax wipe on poly. goes on really smooth so if you're doing a rub-out you don't have as far to go.
PhilBa is offline
post #6 of 19 (permalink) Old 08-17-2015, 11:49 PM Thread Starter
hankh's Avatar
Country: Israel
First Name: Hank
Thanks for the replies. The shellac is dewaxed. I looked again at the can of the the finish that I want to use. Says interior VARNISH. Is there a difference between varnish and lacquer? If so, what is it, and what does it mean in this case?
hankh is offline
post #7 of 19 (permalink) Old 08-18-2015, 01:28 AM
Hank; I googled it...Interior Wood Varnish | Ronseal
No idea why they're so skimpy with the product info but if you scroll down far enough it does say that it's soapy water cleanup. I'd guess that it's some type of acrylic or urethane(?).
No reflection on this product, but my personal approach is to walk a way from products whose manufacturer treats me like an idiot.
Imho, they owe it to the customer to educate them. To give them the benefit of the doubt, perhaps they expect the sales clerk to give you the whole song and dance.
Nickp likes this.
DaninVan is online now
post #8 of 19 (permalink) Old 08-18-2015, 04:18 AM
@hankh ....\
saw you can of varnish tipped over and looked to the bottom of the screen to see what kind of mess ya made...
Dan is putting in the water, again...
BIG OLD TIM likes this.
post #9 of 19 (permalink) Old 08-18-2015, 06:27 AM
First Name: Phillip
Not to hijack the thread; but why put a poly or varnish over shellac? Why not just leave it shellac?
To change the world, change your mind.
phillipdanbury is offline
post #10 of 19 (permalink) Old 08-18-2015, 06:56 AM
hawkeye10's Avatar
First Name: Don
thank you... thank you... THANK YOU!!!!
award graciously accepted...
Stick as the young folks would say you are a "HOOT".
Don
Don in Murfreesboro,Tn.
hawkeye10 is offline
How to do a lacquer finish? DrillingThrough The Finishing Touch 12 08-25-2014 02:54 AM
Working with shellac bobbotron The Finishing Touch 14 12-06-2012 02:58 PM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
French Polishing. derek willis The Finishing Touch 16 02-22-2009 10:18 AM
Sanding Sealer - What is it? Thrifty Tool Guy The Finishing Touch 11 02-21-2009 08:28 AM
