Will Freezing Temperatures Effect Titebone And Other Materials?? - Router Forums
 9Likes
post #1 of 28 (permalink) Old 11-04-2015, 07:37 PM Thread Starter
First Name: Jerry
Default Will Freezing Temperatures Effect Titebone And Other Materials??
Winter is coming, even down here Texas we will most likely get a few days of freezing weather. I have to wonder what damage the cold weather will do to such things as my Titebond glue, both II and III. Also, what about finishs such as Tung Oil?
When I talk about cold weather in my area I'm talking about temperatures at the lowest of 15 degrees which is not cold at all, but I'm still wondering about it. Probably the information is on the label but I prefer to ask member of the forum because their experience is, in my opinion, a better source.
Jerry
Jerry Bowen is offline
post #2 of 28 (permalink) Old 11-04-2015, 07:48 PM
For exterior use, the Construction Adhesives are amazing. You can glue wet wood, pressure treated, frozen wood, etc.
What it isn't is pretty...or precise. !/8" gap? No problem!
LIQUID NAILS Adhesive | Subfloor & Deck Construction Adhesive
LePage / LePage® Construction Adhesives / PL® 400 Subfloor & Deck Adhesive
Titebond - Product
SmartBond Subfloor Construction Adhesive - DAP
Sorry, I know that wasn't exactly what you were asking, Jerry, but it's the route I'd go for anything exposed to weather and cold.
DaninVan is offline
post #3 of 28 (permalink) Old 11-04-2015, 07:49 PM
Oh! And some of the Epoxy glues.
DaninVan is offline
post #4 of 28 (permalink) Old 11-04-2015, 08:05 PM
First Name: Ed
When it gets cold enough to freeze I keep my glues,stains and stuff like that in the house.
rcp612 and DaninVan like this.
herrwood is offline
post #5 of 28 (permalink) Old 11-04-2015, 08:07 PM
Jerry
they don't do cold well at all...
make a carry tray and take them inside or build ya warming box from a cooler and a heating pad inside of it set to low...
BrianS and Litterbug like this.
post #6 of 28 (permalink) Old 11-04-2015, 09:24 PM
First Name: Richard
Reckon it will freeze in an unheated, uninsulated shop like Rick's? Sorry, Rick, the devil made me do it.
Shop guy is offline
post #7 of 28 (permalink) Old 11-04-2015, 09:50 PM
Shadowrider's Avatar
First Name: Scott
Do you have a thermometer in your shop? My "shop" is my attached 2 car garage and I live a ways north of you in Oklahoma. I have a metal insulated door that faces south and it rarely gets below 32. The sun heats that metal door and radiates enough heat in the day to keep it up above freezing for the most part. I do have a propane radiant heater to keep it there during the really cold snaps and when I'm actually working out there.
But I keep my finishes and glues indoors because in the summer I have the opposite problem, it'll hit 100 in there every day. So I just keep them in the utility room cabinet inside.
MEBCWD likes this.
Shadowrider is offline
post #8 of 28 (permalink) Old 11-05-2015, 06:07 AM
Knothead47's Avatar
I use TBIII to glue cork rings for custom fishing rods. Been building for 8 years and haven't had any problems. However, I wouldn't expose the glue or any other liquid or semi-liquid to freezing temperatures.
Note: I just went into my shop and looked at the bottle. It says, in bold letters, "Keep From Freezing."
John T.
Knothead47 is offline
post #9 of 28 (permalink) Old 11-05-2015, 06:11 AM
First Name: Larry
I buy my Titebond III from the local Ace hardware but they don't stock III so it has to be special ordered. The Ace truck is loaded the night before deliver and Ace makes no provisions to keep all the glues from freezing. I stock up in the fall so I don't have to buy glue in the winter. I have four gallons on hand now and that will make it thru the winter. I know this didn't answer your question Jerry but it is something to plan for ahead of time.
Knot working is offline
post #10 of 28 (permalink) Old 11-05-2015, 06:39 AM
First Name: Phillip
Keep your glues and finishes inside.
Also see this:
Making A Heated Cabinet, Page 1
To change the world, change your mind.
phillipdanbury is offline
