Shellac as a sealer? - Router Forums
 1Likes
post #1 of 12 (permalink) Old 03-01-2016, 12:39 PM Thread Starter
First Name: Steve
Default Shellac as a sealer?
I just finished a nice router cabinet to replace my angle iron one and came to the finishing part. I used clear shellac as a sealer before staining. Imagine my surprise when I read the directions on the can. (Yes I'm a man and sometimes read directions). Anyway, the shellac directions said do not use to seal wood for staining. Why not? Does the stain not stick?
I called the company and talked to a rep. who said that it would not work and told me that I would have to sand off the shellac and start over to get the results I wanted.
I suppose I learned a valuable lesson again.
Have any on this forum had a similar experience and if so, what were your recourse?
Knot2square is offline
post #2 of 12 (permalink) Old 03-01-2016, 12:43 PM
PhilBa's Avatar
First Name: phil
Is the shellac dewaxed? I've used dewaxed shellac as a sealer. Note that some premixed shellacs don't say one way or the other. Zinser springs to mind.
When in doubt, try it on a test piece.
Visit my shop website.
PhilBa is offline
post #3 of 12 (permalink) Old 03-01-2016, 01:38 PM
Did he say to stain it first and then shellac or just don't mix the two Steve? And would it make a difference if the stain was oil based or water based. There is also some alcohol based stain, although I've never tried it. Since the shellac uses alcohol for a solvent then that stain should be able to bite into the shellac.
post #4 of 12 (permalink) Old 03-01-2016, 02:23 PM
First Name: Al
I read sealer as exactly what it is "a sealer" Keeps everything out. Oldrusty.
oldrusty is offline
post #5 of 12 (permalink) Old 03-01-2016, 03:10 PM
PhilBa's Avatar
First Name: phil
actually, it's common to use a sealer before stain to prevent blotching. Pine/fir is particularly bad that way.
PhilBa is offline
post #6 of 12 (permalink) Old 03-01-2016, 03:39 PM
White birch and cherry are also bad. I think that concoction that Charles Neil sells is basically a sealer.
post #7 of 12 (permalink) Old 03-01-2016, 04:26 PM
1 lb. cut of de-waxed shellac will work as a conditioner, the stuff Neil sells is a glue sizing, 1 part PVA glue to 3 parts water. You can use drywall mud mixed to a milky slurry.
So many things one can use but also have to remember, if you use a "conditioner", the color will be much lighter.
Always test on a scrap piece.
Zinser seal coat is de-waxed 2 lb. cut, the Zinser shellac has wax, IIRC it is 3 lb. cut.
I would sand it back with 320 - 400 grit and go for the stain, and as said ALWAYS test on a scrap before the "OH [email protected]#$ " moment.
dustmagnet is offline
post #8 of 12 (permalink) Old 03-01-2016, 04:40 PM Thread Starter
First Name: Steve
Thanks fellas. It is Zinser shellac. I suppose it has wax in it, but the can does not say. Anyway, I will try to sand and try to stain again. Another question. I guess that I will have to still put a conditioner or sealer on after sanding, is that correct?
post #9 of 12 (permalink) Old 03-01-2016, 08:23 PM
First Name: Keith
What the conditioner does is to make your stain act more evenly.
Typically softwoods will appear quite blotchy after staining, unless you apply more than one coat...which helps to make the stain appear more even. As you have discovered, the stain won't penetrate the sealer that you used.
Hopefully you can sand it off and start over again. Good luck.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #10 of 12 (permalink) Old 05-31-2016, 12:42 AM
On vacation
Impressive, Nice guide, Liked the suggestions here.
cynthiamyra is offline
Working with shellac bobbotron The Finishing Touch 14 12-06-2012 02:58 PM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
Stripping shellac gav The Finishing Touch 15 03-31-2010 11:06 PM
French Polishing. derek willis The Finishing Touch 16 02-22-2009 10:18 AM
Shellac issues JDługosz The Finishing Touch 5 10-15-2007 12:12 AM
