Tuscan Mirror with Destressed finished on pine - Router Forums
 5Likes
  • 1 Post By Semipro
  • 2 Post By Stick486
  • 1 Post By wags999
  • 1 Post By Cherryville Chuck
post #1 of 10 (permalink) Old 04-12-2016, 05:14 PM Thread Starter
RDSpears's Avatar
First Name: Raymond
Default Tuscan Mirror with Destressed finished on pine
Customer wanted a free standing bathroom mirror made of pine 30x84 with distressed finished. Well I have completed the frame and installed mirror in the frame ready for the finish. Customer chose dark walnut finish and is ok with the samples provided. Now I am trying to determine how to make the finish look distressed with holes notches etc. any suggestions? Thanks in advance. RD
RDSpears is offline
post #2 of 10 (permalink) Old 04-12-2016, 05:25 PM
meat tenderizing hammer..
chain, hammer or your high heel shoes to add dents......
spot sand w/ coarse sandpaper to distress the finish...
Add cracks to the wood using a chisel and hammer....
poke/scratch w/ a screwdriver...
use a wire brush to put on light scratches....
drill small holes
post #3 of 10 (permalink) Old 04-12-2016, 09:29 PM
Semipro's Avatar
First Name: John_*
What Stick said, but think I would remove the mirror first!
Herb Stoops likes this.
Semipro is online now
post #4 of 10 (permalink) Old 04-12-2016, 09:41 PM
he didn't say if he wanted to save the mirror or not....
TenGees and Herb Stoops like this.
post #5 of 10 (permalink) Old 04-12-2016, 10:44 PM
Remember less can be more at times...
Semipro likes this.
wags999 is offline
post #6 of 10 (permalink) Old 04-12-2016, 11:59 PM
I was looking at some distressed finish items at a furniture store and they said they used a glove with a bunch of brads or finishing nails sticking through the back and the wearer kept back-handing the surface until it looked distressed enough.
post #7 of 10 (permalink) Old 04-13-2016, 11:38 AM
Ooooch, that hurts!
Herb Stoops is offline
post #8 of 10 (permalink) Old 04-13-2016, 01:42 PM
Yeah my thoughts too Herb, maybe was specially made with a plate between but the idea is sound- if you like that sort of thing. Maybe driving some nails through a Ping pong paddle instead?
My sister in law had me make a tv stand for her and she used some craft paint that you lightly sand after different coats of different colors. Every time I see it I tell her it looks good, just needs a decent paint job. Different strokes for different folks.
thomas1389 likes this.
post #9 of 10 (permalink) Old 04-13-2016, 06:56 PM
JFPNCM's Avatar
First Name: Jon
Wire wheel on a drill? Vary the speed, pressure and stiffness to create the patterns.
Jon
JFPNCM is online now
post #10 of 10 (permalink) Old 04-14-2016, 11:33 AM
Country: South Africa
First Name: Hentie
if it is going to be painted (but I guess stained only) there are other things you can do.
in the past what I have done, stain first (especially because it is pine) then on some of the spots where it would normally wear, use either a little bit of Vaseline (very very carefully), or rub candlewax over. paint over that. the Vaseline and candlewax affects the sticking of the paint coat. afterwards use a wire brush/scotch brite sanding pad carefully. the places where the paint doesn't stick, will typically be the easiest to get off.
I have also seen where people afterwards use a little bit of gel stain carefully in spots to mimic dirt built up.
lowracer is offline
