How stable is Shellac - Router Forums
 2Likes
  • 2 Post By Cherryville Chuck
post #1 of 7 (permalink) Old 06-20-2016, 04:24 PM Thread Starter
DonBurlWood's Avatar
Default How stable is Shellac
We used to Make a surface by putting almost 10 coats of shellac and sanding in between. It made a VERY smooth surface. My question is how permanent is this. Would the shellac break loose from the wood at some point and is there something that might work better. ?
Donny
DonBurlWood is offline
post #2 of 7 (permalink) Old 06-20-2016, 07:13 PM
Shellac is alcohol based so it tends to sink into the wood and each successive coat bites into the last. There is furniture hundreds of years old that has the original shellac and still in good condition if it was looked after.
DaninVan and Herb Stoops like this.
post #3 of 7 (permalink) Old 06-21-2016, 10:04 AM
MEBCWD's Avatar
If someone spills and alcohol mixed drink on the shellac it will damage the finish. Also some cleaning products will damage a shellac finish. You can build up a finish with shellac then use another more durable finish over the shellac for protection.
MEBCWD is online now
post #4 of 7 (permalink) Old 06-21-2016, 10:19 AM
First Name: lee
My first project in shop class 48 years ago or so was a simple walnut book shelf which I used shellac on. The finish still looks good today.
coxhaus is offline
post #5 of 7 (permalink) Old 06-21-2016, 11:37 PM
stanzee's Avatar
First Name: Stan
My project was a bedside table in shop class in 1950. Been in constant use and still in fine shape. I don't remember how many coats of finish I applied.
stanzee is offline
post #6 of 7 (permalink) Old 06-22-2016, 05:33 AM
hawkeye10's Avatar
First Name: Don
You are so right Chuck. This also make very easy to repair if damaged. Other finishes build on top of each other and can leave ridges in a repair. I think I am right in saying that shellac and lacquer are the only two finishes that does this.
PS- Maybe someone can put this in better words to make this more clear.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 7 (permalink) Old 06-22-2016, 08:50 AM
PhilBa's Avatar
First Name: phil
Shellac is a very good finish for certain applications. It dries fast and is pretty easy to apply, The solvent (alcohol) causes each new coat to fuse with the previous one. You get one thicker layer, not multiple thin ones. A coat tends to be thin so you might have to put a lot more on than WB Poly but it still is pretty quick to do. It's a pretty old finish and you can see examples in museums where the finish is still good (for >100 year old piece). I'd be a lot more concerned about the longevity of some of the new WB Polys out there.
It doesn't have good wear characteristics so generally isn't used for kitchen surfaces, vanities, dining & game tables. I like it for the insides of drawers. Did a recent bedside table in it. Anything that will get even moderate abuse should have something else.
It sprays pretty well but brushing and wiping work too. You do have to be careful with spraying - I've found it's really really easy to put too much on.
Visit my shop website.
PhilBa is offline
Working with shellac bobbotron The Finishing Touch 14 12-06-2012 02:58 PM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
French Polishing. derek willis The Finishing Touch 16 02-22-2009 10:18 AM
Sanding Sealer - What is it? Thrifty Tool Guy The Finishing Touch 11 02-21-2009 08:28 AM
