Slot cutters and biscuits? - Router Forums
 5Likes
post #1 of 18 (permalink) Old 09-13-2016, 09:28 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Slot cutters and biscuits?
For a # 20 biscuit how deep does the slot need to be?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 18 (permalink) Old 09-13-2016, 09:38 AM
Gene Howe's Avatar
First Name: Gene
Would this help?
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 18 (permalink) Old 09-13-2016, 10:22 AM
1/2 the width + 1/32~1/16"
Stick486 is offline
post #4 of 18 (permalink) Old 09-13-2016, 10:30 AM
Some manufacturers advertise certain of their cutters as being able to make slots for biscuits so just check their websites to see which ones are recommended. The big drawback of using a router for making biscuit slots is that you can only make them near an edge.
post #5 of 18 (permalink) Old 09-14-2016, 12:41 AM
TWheels's Avatar
To follow up on the suggestion made by @Cherryville Chuck here is a link to one router bit seller web site slot cutter page that lists which cutters are suited for which size biscuits: A 5/32" carbide height/width of cut/kerf, 9/16" deep cut is what is listed for #20 (and #10 and #0) biscuits.
MLCS Slot Cutter Router Bits and Stackable Slot Cutter Set
Although I am far from expert on this topic (read "I know what a biscuit is") having read enough posts by @Stick486 I wonder if splines would not be better.
hawkeye10 likes this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #6 of 18 (permalink) Old 09-14-2016, 12:58 AM
yes they would...
Stick486 is offline
post #7 of 18 (permalink) Old 09-14-2016, 06:41 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Thanks Tom for your suggestions. I do use splines at times and biscuits on occasions. You might say I go both ways but only in wood working.
post #8 of 18 (permalink) Old 09-14-2016, 09:49 AM
Gene Howe's Avatar
First Name: Gene
JMHO, splines nor biscuits provide much more than an alignment aid. Except in a very few instances do they add a measurable amount of strength to a glued joint.
Again, JMHO, they are a waste of time.
YMMV
Herb Stoops likes this.
Gene Howe
Snowflake, AZ
post #9 of 18 (permalink) Old 09-14-2016, 11:06 AM
YMMV
sorry you feel that way about splines...
Stick486 is offline
post #10 of 18 (permalink) Old 09-14-2016, 11:49 AM
Gene Howe's Avatar
First Name: Gene
So, educate me about those applications where they are useful.
Hey, I'm still larnin'.
Gene Howe
Snowflake, AZ
Slot cutter recomendation Noob Router Bits - Types and Usage 18 06-02-2009 06:40 PM
any thought about this bit set tryingtokeepmyfingers Router Bits - Types and Usage 4 05-29-2009 11:10 PM
need wood working wisdom Michel A. Turcotte New Member Introductions 6 02-21-2007 10:24 PM
Biscuit Joints with a router rprice54 General Routing 7 08-28-2006 01:02 PM
