How do I router out a small, shallow pocket? - Router Forums
 14Likes
post #1 of 22 (permalink) Old 09-16-2016, 06:10 PM Thread Starter
Default How do I router out a small, shallow pocket?
Hi guys,
I am new to the forum, and hopeful that you can help me with a project. I am doing some custom knife handles, and the knives are spring assisted, so I need to put the spring pocket in the one side of one of the handles. I have to do this for 10 knives. I was thinking of building a small router table, and that I could put a matching pocket in a piece of aluminum or something as a guide, but the smallest corner is only going to fit a 1/8" cutter. I am new to using a router as well, so ANY advice will be hugely appreciated. There will 5 done in micarta, and 5 done in stabilized walnut. The handle blanks will be 4.5x1.5" and the pocket needs to be .082" deep. Because of the precision of these knives, and the action of the spring, these pockets need to be quite precise. I attached a photo of the stock handle, as reference.
Cheers,
Dustin
You can see my work on Facebook and Instagram @Tocherdesigns
Dustin Tocher is offline
post #2 of 22 (permalink) Old 09-16-2016, 06:29 PM
old55's Avatar
First Name: Ross
Welcome to the forum Dustin. I can't help with your inquiry but I'm sure someone will be along to give some advice.
Ross,
old55 is online now
post #3 of 22 (permalink) Old 09-16-2016, 06:32 PM
Hello Dustin and welcome to the forums...
see if this helps..
Making Inlays With A Router - NewWoodworker.com LLC
Stick486 is offline
post #4 of 22 (permalink) Old 09-16-2016, 07:31 PM
Welcome Dustin. To build a bunch and get them accurate and all the same you need a pattern or template or you need to farm them out to someone with a CNC router which you might want to check out. To rout the entire cavity with a 1/8" bit will be slow. I would rout most of it out with a larger bit and switch to 1/8" to finish the tight spots. You need a fairly short bit with a top bearing such as a small mortising bit to do the major cutout. The next problem is that there are no top bearing 1/8" bits so you would have to switch to a template guide and probably a different template for the last cuts or just chisel the last bit out instead which could be a lot faster than it may sound to you.
RainMan 2.0 likes this.
post #5 of 22 (permalink) Old 09-16-2016, 07:43 PM
Honored Member
First Name: pat
Way too spooky on the router table.
In my view, has to be done with hand routers.
& you're asking a lot from ground zero.
An understanding of the whole megillah is paramount.
You can see how many templets it takes to get to the work here.
And there were other templets to make these.
I'd be thinkin' laser templet routing, (have it done x a pro).
Complimentary template routing (CTR) is the end game in this art.
Not the beginning.
jw2170 and OPG3 like this.
Quillman is offline
post #6 of 22 (permalink) Old 09-17-2016, 10:52 AM
MEBCWD's Avatar
Make a template that you can use with a router collar and 1/8" bit. This post may help http://www.routerforums.com/guide-bu...beginners.html
You might see if you can find someone local with a CNC that could do the work at a reasonable cost and they could cut all the pockets and drill all the holes. They could even do 2 sided carving and contour the grip.
Or you could have them make a template for you to use with a router collar to cut the pocket that you could use over and over.
MEBCWD is offline
post #7 of 22 (permalink) Old 09-17-2016, 01:58 PM
RainMan 2.0's Avatar
I'm with you Mike , as soon as I seen it cnc came to mind . I'd like to see it done with a plunge router , but the template would be a pita too make IMO
MEBCWD likes this.
Ok ,I never insulate
RainMan 2.0 is offline
post #8 of 22 (permalink) Old 09-17-2016, 02:43 PM
woodnthings's Avatar
First Name: "BILL"
I see 2 pockets, and 3 recessed holes... too much for a simple template in my opinion AND what about the other side of the knife scale? There may be more pockets and holes on that one. A CNC is the way to go , and if you don't own one, you can buy one or rent time on one, OR farm out the entire project. Once programmed, the rest will be a 5 minute routing job, no limit to the number of pieces you can make.
woodnthings is offline
post #9 of 22 (permalink) Old 09-17-2016, 02:50 PM
gjackson52's Avatar
First Name: Gary
Welcome to the forum !
Gary
gjackson52 is offline
post #10 of 22 (permalink) Old 09-17-2016, 03:40 PM
The Hobbyist's Avatar
First Name: Joe
That project just screams for a CNC router. I can do it on my table, but you are in Canada, so ...
If you will be making more of these types of cuts, you might want to invst in an X-carve CNC machine or something like the Piranha or Laguna CNC router machines.
Joe
Piranha CNC machine
Laguna CNC machine
http://www.aguyintown.com
Retirement is overrated.
The Hobbyist is offline
Question - small router table or table-top Hawks_Feather Table-mounted Routing 14 12-15-2012 09:16 AM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
