Round baseplate for Bosch mrp23 - Router Forums
post #1 of 6 (permalink) Old 09-18-2016, 03:13 PM Thread Starter
Drosner's Avatar
First Name: Dave
Default Round baseplate for Bosch mrp23
Hi - I'm building a simple jig for a mortise that is 3imch deep and 3/4 wide. I have a 1/2 inch diameter but with a 3inch long cutter. So I'll need to do 2 passes.
In order for me to get the end to end width consistent I have stops and plan to just rotate the piece with the jig attached and I'll get a perfectly centered mortise.
Problem is that the base that comes with my Bosch mrp 23 plunge router has a straight edge on one side of the base plate. So the distance to the stops from the router plate differs depending on which side I'm on.
Figure I could just get an after market plate that is round and perfectly centered. I was going to try to make my own plate but getting it perfectly centered seems like I need an engineering degree and a machinist apprentiship.
I've searched the Internet far and wide and can't seem to find one. What am I missing ?
Drosner is offline
post #2 of 6 (permalink) Old 09-18-2016, 03:33 PM
Try Pat Warner - he makes a baseplate with adjustment that can be centered to the spindle. Either the package or the basic model which can be centered using one of the cone tools.
Precision Subbase Kit
tomp913 is online now
post #3 of 6 (permalink) Old 09-18-2016, 06:02 PM
First Name: Jerry
+ Pat Warner
Bonka is offline
post #4 of 6 (permalink) Old 09-19-2016, 11:45 AM
Nickp's Avatar
First Name: Nick
...why can't you orient the flat side of the base towards the cut in each of the directions...?
Nick
Nickp is offline
post #5 of 6 (permalink) Old 09-19-2016, 05:19 PM
This is a perfect job for guide bushings. If you don't already have the following items I highly recommend that you get them. The Bosch:
RA1151 centering cone to properly center your sub base plates or mounting plate to the router.
RA1126 quick release adapter.
RA1100 PC style guide bushing adapter that lets you use all PC style guide bushings in your router.
A set of brass PC style guide bushings with all the collars slightly under 1/4" length; available from many sources.
Four pieces of 1x3" set as shown in the Trend Varijig photo are your guides. Hold them down with double sided carpet tape; a small piece of 1x3" attached to one side of your routers sub base plate will keep it from tipping on large jobs.(But you won't need it for the task you described)
post #6 of 6 (permalink) Old 09-20-2016, 06:49 AM Thread Starter
Drosner's Avatar
First Name: Dave
Removing the plate and reinstalling 90degrees is a genius idea - thanks nick
Thanks Mike for the details. That setup may work and I could use guide bushings many times in the future. Just not sure if my 8/4 thick stock is enough platform to support the setup?
Drosner is offline
Coping with quarter round Gaffboat Jigs and Fixtures 13 06-28-2015 12:24 PM
Large quarter round? cokewithvanilla General Routing 13 09-15-2014 01:48 PM
Round over bit. On 1.5mm & 3mm Wood. Possible? mouchmouch Router Bits - Types and Usage 3 05-06-2013 10:32 AM
Do I need to use the plastic baseplate when mounting a router to a router table? bighank Table-mounted Routing 8 02-25-2013 09:56 AM
Looking to commission woodworker for round end table Hockeystyx Tools and Woodworking 1 10-26-2009 10:14 AM
