Safety Glasses with side shields - Router Forums
 9Likes
  • 2 Post By Gaffboat
  • 1 Post By kp91
  • 1 Post By DesertRatTom
  • 2 Post By Cherryville Chuck
  • 1 Post By CAD-Man
  • 2 Post By MEBCWD
post #1 of 9 (permalink) Old 09-24-2016, 03:40 PM Thread Starter
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Default Safety Glasses with side shields
I would like the members opinions on the following:
Is there a comfortable pair of safety glasses with side shields that will fit over regular prescription lenses?
Are the available add on side shields for prescription glasses worth anything?
Of the above would you recommend one brand and/or one style over another?
One supplier over another?
Full face shield is not really an option.
Thank you.
smitty
smitty10101 is offline
post #2 of 9 (permalink) Old 09-24-2016, 03:58 PM
Gaffboat's Avatar
First Name: Oliver
I bought this pair from Infinity Cutting tools. They arrived this morning and I wore them for several hours in the shop. They are very comfortable and I truly could not tell I was wearing them. They fit over my regular glasses like a charm. Here's the link: Over-the-glasses safety glasses.
chessnut2 and Nickp like this.
Gaffboat is offline
post #3 of 9 (permalink) Old 09-24-2016, 04:24 PM
kp91's Avatar
First Name: Doug
Some of my guys use Prescription Safety Glasses | Prescription Safety Eyewear | Bifocal Safety Glasses | Rx Safety
I use these UVEX glasses, they can be a little heavy until you get used to them, but they fit my bigger than average melon.
Uvex Astro OTG 3001 | Eye and Face Protection | Honeywell Safety
We have a couple of clip on side shields for visitors, I particularly don't care for either style, but some guys swear by them.
PIP 252-FX-0001 100% Vinyl Universal Flex Sideshields | FullSource.com
https://www.amazon.com/B26-Safety-Gl.../dp/B007X3LMJK
https://www.industrialsafety.com/3M-...FYqIfgodT5EDww
My biggest problem with all of the clip on side shields is the bad optics. I would rather they be totally opaque.
RainMan 2.0 likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 9 (permalink) Old 09-24-2016, 05:49 PM
chessnut2's Avatar
I like how clear the side shield part is. The place I used to work required us to use the clip-on shields, and peripheral vision was almost nil. There were a lot of close calls from people stepping into the aisles with oncoming fork truck traffic closing fast.
chessnut2 is offline
post #5 of 9 (permalink) Old 09-24-2016, 11:24 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Go to an optician specialising in shooting glasses. They all come with side protection so just have your normal prescription lenses fitted.
sunnybob is offline
post #6 of 9 (permalink) Old 09-25-2016, 09:37 AM
Most opticians can make up a pair of plano (No Rx) glasses, but if you want one with your Rx in it, you will have to see an optometrist or if necessary, an ophthalmologist. If you are much older than 40, you need to emphasize to the doctor that your using these for near work. Take a tape measure and measure your usual working distance. If you want an oversized lens (wraparound), you will likely have to get a bifocal with a line. I don't think anyone is making a progressive (no line) in wrap around. I have a great pair of sun glasses that wrap around, just too dark for shop use.
I like Oliver's solution best of anything I've seen so far to wear over normal sized glasses. But if you have a really large pair of glasses, they might not quite fit. The pair Oliver suggested is only about $7, so you can order several pair , given that so many of us have the put-em-down-somewhere-but-I-can't-remember-where syndrome. That means at least 4 pair for me.
Gaffboat likes this.
post #7 of 9 (permalink) Old 09-25-2016, 09:43 AM
I also have a very large melon for a head and Norton 18000 or 18001 safety glasses fit over my glasses with ease and they are light and also very cheap. I think they are only $2-3 here in Canada.
kp91 and DesertRatTom like this.
post #8 of 9 (permalink) Old 09-25-2016, 12:47 PM
First Name: Bruce
I just purchased 2 pair of these Fit over Perscripton Glasses Safety Glasses from Rockler. They are very comfortable and you don't need to wear ear muffs with them.
Bench Dog® Soundshield Safety Glasses, Fit Over Glasses Style | Rockler Woodworking and Hardware
CAD-Man
marecat3 likes this.
CAD-Man is offline
post #9 of 9 (permalink) Old 09-27-2016, 08:29 PM
MEBCWD's Avatar
I like the side shields but I also know that your regular glasses are probably not safety rated. The last company I worked for paid for a pair of prescription safety glasses every year and since my prescription did not change one year I had them make a set with the bifocals in the top instead of the bottom for working on over head projects, it sure saved your neck by the end of the day.
MEBCWD is offline
What price do you put on safety? kp91 General Routing 21 07-23-2010 02:10 AM
Is workshop safety needed? Check twice! Shop Safety 18 07-12-2008 10:27 PM
Safety Question beers_4 Shop Safety 4 01-29-2007 06:02 PM
new router has side to side movement whilst plunging??? matey General Routing 2 11-11-2005 02:09 PM
