Bosch GOF 1600 CE Won't Start - Router Forums
 3Likes
post #1 of 17 (permalink) Old 10-05-2016, 09:11 AM Thread Starter
Country: Israel
Default Bosch GOF 1600 CE Won't Start
Hi,
My router won't start anymore. I tried cleaning it out as much as I dared to take apart. It doesn't start in the plunge or fixed base. The LEDs are working and when I try starting the router I hear two clicks about a second or two apart. Once in a while it will start up for a second, but that's it.
Any ideas?
sammarkowitz is offline
post #2 of 17 (permalink) Old 10-05-2016, 10:54 AM
MikeMa's Avatar
Isn't that a the European version of the MRC23? From your profile, you are in the U.S. Are you running this on a 220V Plug?
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #3 of 17 (permalink) Old 10-05-2016, 12:50 PM
Welcome Sam. Some of the older Bosches had a problem with sawdust getting in the switch. If yours doesn't have a plastic cover over the switch then that might be a possibility. A broken wire in the cord might but if you move the cord around with the router on it should make contact occasionally. It might be the brushes. Check your parts schematic for how to get to them. It might also be the electronics. For that you probably need to take it to a repair shop and let them test it.
post #4 of 17 (permalink) Old 10-05-2016, 01:12 PM Thread Starter
Country: Israel
Yep, that's the one, but I'm not in the US. I'm indeed running off of 220.
RainMan 2.0 likes this.
post #5 of 17 (permalink) Old 10-05-2016, 01:40 PM Thread Starter
Country: Israel
It seems like the brushes are indeed the problem. I've finally located and (sort of) removed them and they're all chipped at the ends. Hopefully I can figure out the right way to replace them. Doesn't seem to be too much info online. Looks like it shouldn't be too bad once I figure out how to get them off the contacts without breaking the whole thing. This is my first time around doing this. Thanks for the help.
post #6 of 17 (permalink) Old 10-05-2016, 06:14 PM
Some tools make it easy. They have plugs over them that you can unscrew. Others are more difficult requiring that you pull the armature part way out so that they can be removed inwardly.
post #7 of 17 (permalink) Old 10-05-2016, 08:45 PM
see if this helps...
brille and jj777746 like this.
post #8 of 17 (permalink) Old 10-06-2016, 01:07 AM
Be more inclined to think brushes as to have the switch in both the fixed & plunge base break at the same time would be a pretty big coincidence. At times I have had to remove & replace the router in the base to get it to start.
Nobodi is offline
post #9 of 17 (permalink) Old 10-06-2016, 02:01 AM Thread Starter
Country: Israel
Well, they didn't make it easy in this one. I can get the brushes out easily enough, although the coiled spring holding them in is a little awkward to get out of the way. It's the contacts that I find perplexing. I'm not quite sure whether I should be giving the contacts a good pull to remove them (a gentle pull doesn't make them budge) or if I have to take more of the darn thing apart. Maybe when I get the new brushes it will be more evident.
post #10 of 17 (permalink) Old 10-06-2016, 11:35 AM
Sam the brushes and holders, and sometimes the springs, are usually all one unit.
Bosch GOF 1600 CE AllanG Tools and Woodworking 1 08-24-2014 10:28 PM
Converting a Bosch RA1180 to a table LagunaPaul Table-mounted Routing 31 08-11-2014 09:45 PM
simple router table - attach vacuum hose to router box, or use Bosch dust adapter? achoox4 Table-mounted Routing 7 07-07-2014 04:01 AM
LF Alum. Router Mnt. Plate for Bosch MR 23 GEBonez Table-mounted Routing 8 02-26-2014 09:51 AM
Bosch 1617vs Verses 690 Porter cable Glenmore Tool Reviews 20 08-09-2009 09:36 PM
