Cleaning up acrylic cut using router - Router Forums
 14Likes
  • 3 Post By RainMan 2.0
  • 3 Post By TenGees
  • 2 Post By RainMan 2.0
  • 3 Post By andyk
post #1 of 10 (permalink) Old 11-22-2016, 06:43 PM Thread Starter
First Name: Tony
Default Cleaning up acrylic cut using router
I have to cut some 1/8" acrylic. I was going to use my table saw with a thin kerf 72t blade. However I'm expecting I'll have to clean up some edge chipping using the router.
I'm new to routing, I've used my router free hand a few times but I've not made much use of my router table yet.
Is there any way to do the edge cleaning on the router table or am I better off clamping an edge guide to the work and running the router freehand?
To use the router table I'm thinking I'd need a very slight additional thickness on the fence behind the bit to make up for the material removed.
Thanks and sorry if this is a n00b question
dorkshoei is offline
post #2 of 10 (permalink) Old 11-22-2016, 07:05 PM
Honored Member
First Name: pat
Extreme control on the table saw will produce a near chatter free edge.
Jointing on the router table is more forgiving but will still leave
a mill mark. You could be trading one set of chatters for another.
However, wet sanding will remove the mill marks from the saw or router.
Quillman is offline
post #3 of 10 (permalink) Old 11-22-2016, 10:37 PM
RainMan 2.0's Avatar
I cut 12mm plexi and lexan on my table saw , then clean it up on my belt sander with 220 . You can get it to a clear edge if you use a rag with toothpaste on it and a lot of elbow grease.
If your lazy like me , you can use a torch to get a clear edge after sanding . You have to be very careful as it's very easy to burn the plexi if you hold it to long . I put masking tape on both faces and just leave the edge exposed so they don't damaged by the heat
chessnut2, Nickp and Roy Drake like this.
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 10 (permalink) Old 11-23-2016, 06:57 AM
CharleyL's Avatar
First Name: Charley
There is also a way of turning the edge clear like he face surface, by carefully melting the edge with a heat gun or torch, but it requires extreme skill to get right without destroying the piece. Thinner pieces require even more skill, or luck.
Charley
Central North Carolina
CharleyL is offline
post #5 of 10 (permalink) Old 11-23-2016, 07:14 AM
TenGees's Avatar
First Name: Paul
In the sign business, I found that the edge from a router was typically cleaner and easier to smooth. For a while we heated the edge but found that this can cause small cracks in some plexi, which may not show up right away. I think it's worse with colours (the additives maybe?). So we switched to buffing the edges on a bench grinder setup. Unless there was obvious divots we didn't even sand the edge. We had a 1 by 6 inch plexi bar for a fence.The machinist next door kindly took a 1/16 off of half of it. If we cut parts on a panel saw, we would route the edges anyway to clean them before buffing.
If you have methylene for gluing parts, you can try wiping the edge with a rag moistened with it. That works well but you have to be careful not to get any on the face.
Nickp, Roy Drake and RainMan 2.0 like this.
TenGees is offline
post #6 of 10 (permalink) Old 11-23-2016, 08:24 AM
Paul, good point about weakening the edge with heat . Plexi actually gets small cracks if the surface to be glued was cut with a laser
TenGees and Nickp like this.
post #7 of 10 (permalink) Old 11-24-2016, 09:02 AM
chessnut2's Avatar
This should be mentioned as a shop hack! Thanks, Rick. I'll use the idea.
chessnut2 is offline
post #8 of 10 (permalink) Old 11-24-2016, 06:35 PM
I laughed as I asked the lady at a hobby shop if they had any plexiglass polish , and she replies with , well do you have any toothpaste ?
And I'll be dammed if it didn't work , and smelled minty afterwards too
After seeing how abrasive it was , I was kinda concerned with brushing my teeth too much after that though
TenGees, Nickp and Roy Drake like this.
post #9 of 10 (permalink) Old 12-10-2016, 04:52 AM
First Name: Andy
When I did acrylic fabrication we used routers for edge preparation and then used a torch for the edges. The trick with a torch is to use hydrogen/acetylene instead of an acetylene/oxygen mix. Use a small fine flame and don't hesitate as you're running the torch along the edge. Been doing that for 45 yrs. with no issues.
TenGees, Nickp and RainMan 2.0 like this.
andyk is offline
post #10 of 10 (permalink) Old 12-10-2016, 04:03 PM
Great tip . That's interesting Andy , I wasn't aware the of that
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
