Re installing the springs on a PC model 7539 router... - Router Forums
 2Likes
  • 2 Post By Herb Stoops
post #1 of 5 (permalink) Old 11-28-2016, 04:56 PM Thread Starter
Default Re installing the springs on a PC model 7539 router...
...this is a heavy duty 3.5 hp plunge router - the largest Porter Cable makes. I used it for years in a table I made and it worked great. In order to use this plunge router in a table I removed the springs in both handles.
Now I want to reinstall those springs and use it for general routing not mounted in a table. It has been very difficult to try to compress these 18 inch springs back into their cylinder holes on the router.
The resistance to compression is so great that the springs buckle and fly out every time. Is there a tool that can help me do this, or a way to compress those springs back into the holes ?
I made a few experimental jigs and nothing works to this point.
To me, the solution would be to keep the springs straight as they compress down into the holes while they are exerting an upward resistance to compression. Not easy to to this.
I know repair shops probably have a dedicated tool for this, but I'd like to avoid bringing it in just to reinstalll the springs.
I contacted Porter Cable and they do not have any tool to do this.
Those who are familiar with a PC7539 should understand what I am talking about
Thanks for anyone's help.
cr
rabchaz is offline
post #2 of 5 (permalink) Old 11-29-2016, 12:48 AM
Country: Italy
First Name: Stefano
Can you attach a picture? Some idea can come!
Inviato dal mio iPad utilizzando Tapatalk
steveb2l8 is offline
post #3 of 5 (permalink) Old 11-29-2016, 09:11 AM
Here is a crazy idea, Find some PVC pipe that goes over the springs. Cut into 2" lengths. Wire them back together and stack them onto the springs. As you compress the springs to a point that you need to remove the PVC cut the wires and compress to the next one and so on til you can compress it down to the last one.
Just saying,
Nickp and RainMan 2.0 like this.
Herb Stoops is online now
post #4 of 5 (permalink) Old 11-29-2016, 01:11 PM
JFPNCM's Avatar
First Name: Jon
At one time automotive supply stores carried spring compressors that resembled an overgrown pair of pliers. Some had closing bolts such that they could be cranked down as it were. A quick Google search of hand spring compressors turned a few photos but I could not download any of them. Another consideration would be vise grips with forked tangs.
These may be far larger than what your looking for though.
Jon
JFPNCM is offline
post #5 of 5 (permalink) Old 11-30-2016, 11:07 PM
First Name: JT (Jim)
I recently took mine apart to clean and lube the tubes and sleeves. Yes it can be a bit of trouble to reassemble. For the life of me I can't remember what I did to make it go back easily. Tomorrow I will pull the router out and see if I can remember. Getting older has presented a few blockades now and then.
subtleaccents is offline
Manual for Craftsman 2HP combo router (model 320-27683) Niku New Member Introductions 12 04-01-2014 04:31 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Router lift for PC 7539 plunge router. tnelson460 Table-mounted Routing 5 09-10-2011 08:39 AM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
Removal of router springs for table use pianoman8 The Voting Booth 20 11-08-2007 03:58 PM
