Long hole boring - Router Forums
 6Likes
  • 6 Post By Bob Gibson
post #1 of 3 (permalink) Old 11-30-2016, 12:00 PM Thread Starter
Country: New Zealand
First Name: N/aBob
Smile Long hole boring
I needed to bore a 16 mm hole in a piece of wood 600mm long, I tried to do it on the lathe, and from both ends, but they never met up.Then i had the bright idea, cut the timber in half lengthwise, then run it through on the router table with a domed bit, brilliant, then i glued it back together, put the steel rod through as an axle, and turned it perfectly round.
Bob Gibson is offline
post #2 of 3 (permalink) Old 11-30-2016, 12:08 PM
Good solution Bob. I believe that spoon bits were traditionally used to bore long holes as I think they are not prone to wander as much as traditional bits but finding one that long could be a challenge.
post #3 of 3 (permalink) Old 11-30-2016, 07:04 PM Thread Starter
First Name: N/aBob
Yes! i have looked for augers,( think that is the term) but they are really just long engineering drills , or a screwed end woodworking drill, haven't seen any spoon bits locally! not to worry , my router did the job,its an amazing tool.
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 11:19 AM
Hole Tolerance using a Hole Saw Kevin Witt New Member Introductions 11 07-17-2014 08:21 PM
Small Circle Cutting (no centre hole) Cowbell General Routing 14 05-26-2014 08:20 AM
pocket hole uses and feasibility g19fanatic Jigs and Fixtures 25 09-14-2010 09:06 PM
hole saw vs forstner bit reds_21 Tools and Woodworking 6 03-20-2005 09:48 AM
