Wierd Situation - Router Forums
 5Likes
post #1 of 18 (permalink) Old 12-05-2016, 08:25 PM Thread Starter
Default Wierd Situation
Hi Everyone,
I had a weird situation recently and hope one of you have an answer to this. I am making kitchen cabinets using the Summerfeld "Tongue and Groove" bits that I have used before without incident. This problem happened while making the stiles and rails of the faceframe.
I was using my router table with a Triton 3 1/4 HP router using the Sommerfeld Tongue and Groove 1/2" bits to groove faceframe stiles made from really hard wood (Santos Mahogany). After about grooving about 10 feet, I noticed that the groove had climbed about 3/8th's of an inch in the stiles I was grooving. As you can imagine, I was not happy.
As I begin my inspection, it discovered that the groove had begun to climb almost immediately after the first 2 boards. The climb was gradual and not the result of any impact or other sudden shift in position of the bit. I had no jams or other surprises during the process. The grooving was very smooth, just in the wrong place.
I began inspecting the machine to see what happened as I expected to find that the router itself had moved or the locking mechanism on the router lift had failed. But no, neither of those were the cause of the problem. I discovered that the Sommerfeld bit had actually climbed upward in the collet.
Just in case you're going to say it was a loose collet, it wasn't. The collet was quite tight when I went to take the bit out. Once I loosened the collet, the bit dropped quite easily to the bottom of the collet.
I am completely stumped. What would cause the bit to inch upward during a grooving operation? Could this have been caused by the angle of the cutting edge of the bit and the hardness of the wood? I've never had this happen before.
I don't want to continue using the Triton router in the table if it is going to do this again. The wood is really expensive and takes quite a bit of work to get it to the grooving stage.
Any ideas or suggestions? I sure would appreciate the help.
Thanks,
Bill
SoCal (Orange County)
chessnut2 likes this.
wildcoach is offline
post #2 of 18 (permalink) Old 12-05-2016, 09:30 PM
Sommerfeld bits are supposed to be used with a grommet dropped into the collett. If the gromet wasn't there, then the bit might be able to shift. You might want to look up Triton, but I have also had some nice communications with Marc Sommerfeld and you might go on the site and contact him about this problem Betcha a buck he knows what happened and how to fix it. I had a Rockler lift that did this because there was an odd, friction dependent lockdown mechanism.
post #3 of 18 (permalink) Old 12-05-2016, 09:52 PM
First Name: Clay
Great first post. Welcome to the forum.
chessnut2 and Roy Drake like this.
fire65 is offline
post #4 of 18 (permalink) Old 12-05-2016, 10:24 PM
Welcome Bill. Was the collet clean and if the bit was new did you make sure any anti corrosive compound was cleaned off first? Also as Tom mentioned you have to make sure the end of the bit is not bottomed out in the router's arbor. The bit won't tighten properly if it is.
post #5 of 18 (permalink) Old 12-05-2016, 10:35 PM
BrianS's Avatar
First Name: Brian
Hi Bill. Welcome to our little corner of the 'net.
It sounds to me like maybe the collet was not tight enough. Maybe, as Charles suggested, dirt in the collet, or on the shaft of the bit. Or, maybe a burr of some kind on the shaft. Or, and this is a very common thing, you bottomed the bit in the router and then tightened the collet. The collets are designed to pull the bit down slightly when it is tightened. If it can't pull the bit, then it will not tighten properly. This the reason for the grommet that Tom mentioned... the bit rests on the grommet, and then the collet can tighten properly by pulling the bit down against the grommet. This also ensures that your bits are always the same height in the collet.
old55 likes this.
Brian
(Origin uncertain)
BrianS is offline
post #6 of 18 (permalink) Old 12-06-2016, 01:25 AM
jj777746's Avatar
Originally Posted by wildcoach View Post
Hi Everyone,
Thanks,
Bill
Hi Bill,you say the bit dropped to the bottom of the collet when you loosened it. I have the same Triton as you & I have never had that happen.Sounds like a faulty collet.Let us know the answer if & when you find it.James jj777746
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #7 of 18 (permalink) Old 12-06-2016, 03:44 AM
JOAT's Avatar
First Name: Theo
My problem with that happening ended when I started dropping the bit in, then raising it about 1/8" before tightening. Never happened again.
JOAT is online now
post #8 of 18 (permalink) Old 12-06-2016, 08:22 AM
First Name: Art
Is this the only bit that raises on it's own? If so it could be a faulty bit.
mgmine is offline
post #9 of 18 (permalink) Old 12-06-2016, 08:51 AM
Knothead47's Avatar
Welcome to the forum!
John T.
Knothead47 is offline
post #10 of 18 (permalink) Old 12-06-2016, 09:34 AM
First Name: Ken
I hope you find an answer to this as I have had it happen before too, but not with that router or bit (I don't own either).
kklowell is offline
A Hairy Situation williamyoung Pyrography and Carving 21 02-12-2016 06:52 PM
Current situation harrysin Lobby 38 11-29-2015 06:29 PM
This was weird...routing a taper...? Nickp General Routing 6 01-30-2015 10:17 AM
Bad situation. papasombre Lobby 18 10-21-2014 07:25 PM
smelly situation junglejim Lobby 10 07-15-2013 12:05 AM
