so how does this cut? - Router Forums
 4Likes
  • 3 Post By DesertRatTom
  • 1 Post By Job and Knock
post #1 of 9 (permalink) Old 12-13-2016, 02:56 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default so how does this cut?
Found two of them in my recent tool haul. 3/8" shank
sunnybob is offline
post #2 of 9 (permalink) Old 12-13-2016, 03:30 PM
Whatisit? A bit?
Herb Stoops is online now
post #3 of 9 (permalink) Old 12-13-2016, 05:13 PM
That might be a plastic cutting bit but not sure.
post #4 of 9 (permalink) Old 12-13-2016, 05:47 PM
When I had my last shed built, the crew used this in a router to make cuts in 4x8 sheet goods. Drilled a home and used this to cut out window openings. Made a very clean cut.
DesertRatTom is online now
post #5 of 9 (permalink) Old 12-14-2016, 07:10 AM
CharleyL's Avatar
First Name: Charley
I found that router bits with only one flute tended to vibrate if cutting anything of any significant thickness. The only thing that I use them for now is trimming laminate, where they work well for me.
Charley
Central North Carolina
CharleyL is offline
post #6 of 9 (permalink) Old 12-14-2016, 08:44 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I just cant see it. Surely if the bit falls into the material and then gets pushed back out at a rate of 20,000 times a minute, it would shake to pieces?
sunnybob is offline
post #7 of 9 (permalink) Old 12-18-2016, 12:15 PM
First Name: Eric
It's one of two things; possibly it's an acrylic cutter (what Onsrud refer to as an O-cutter) or it's a single flute cutter designed to be used in the eccentric chuck of an overhead pin router. Either way it's designed for fast and slightly rough production cutting
Cherryville Chuck likes this.
Job and Knock is offline
post #8 of 9 (permalink) Old 12-18-2016, 12:39 PM
Welcome to the forum Job. That's what I thought too, that it resembled Onsrud's O flute plastic cutting bits.
When you get a minute why not finish filling out your personal profile so we don't have to refer to you as Job and Knock.
post #9 of 9 (permalink) Old 12-18-2016, 07:49 PM
old55's Avatar
First Name: Ross
Ross,
old55 is offline
Push Blocks & Push Sticks Moz Shop Safety 106 06-26-2016 03:37 AM
measure twice, cut mumble... PhilBa Lobby 22 08-23-2015 04:55 PM
How to cut slots in 2 pieces that are not straight on outsides. Midnight Shadow General Routing 4 07-26-2010 11:04 AM
Squaring plywood panels ShaneB Table-mounted Routing 46 10-14-2009 05:28 PM
Now, how I cut my tnons with a router. derek willis Table-mounted Routing 11 01-27-2009 09:51 AM
