zero setting - Router Forums
 1Likes
  • 1 Post By vchiarelli
post #1 of 7 (permalink) Old 01-03-2017, 12:22 PM Thread Starter
Default zero setting
How do I establish zero setting, is it by adjusting the bit or the scale or ??
stan herman is offline
post #2 of 7 (permalink) Old 01-03-2017, 12:48 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the router forum,Stan
I preferred to adjust the bit, that would be my preference
Thank You John
Semipro is online now
post #3 of 7 (permalink) Old 01-03-2017, 01:08 PM
First Name: Earl
Hi Stan--welcome aboard.
We might get closer to a right answer if we knew the zero setting on what? I immediately thought of Incra positioner, John seems to have a thought on something else, could be a Wixey angle cube, depth of cut, distance from center...
What are you referring to?
earl
greenacres2 is offline
post #4 of 7 (permalink) Old 01-03-2017, 01:13 PM
vchiarelli's Avatar
First Name: Vince
@stan herman - welcome to the forum. More details would certainly help, but I'll guess that you want to zero out a bit on a plunge router. If that is the case, plunge the bit down until it reaches the top of your material, that's the zero setting. Then, using a brass bar or something similar, lift the bar near the scale and above the turret, by the amount you want to plunge the bit down. Then when you plunge the bit will plunge down by that amount. You can use several steps on the turret to reach your level as you don't want to plunge too deeply at one time.
Hope this helps, if not please explain what you are trying to do.
JFPNCM likes this.
vchiarelli is offline
post #5 of 7 (permalink) Old 01-03-2017, 02:10 PM
Semipro's Avatar
First Name: John_*
Watch see if this helps
post #6 of 7 (permalink) Old 01-03-2017, 09:53 PM
old55's Avatar
First Name: Ross
Welcome to the forum Stan.
Ross,
old55 is offline
post #7 of 7 (permalink) Old 01-04-2017, 01:09 AM
Hi Stan and welcome. Here is a link to some routing tutorials that member Harry Sinclair prepared a while back and during the course of them he shows what you are asking about. http://www.routerforums.com/guide-bu...tutorials.html
Only One Miter Lock Setting Jerry Bowen Tools and Woodworking 26 01-05-2015 12:29 AM
Setting Steps per Inch in Mach3 bgriggs CNC Routing 2 05-23-2014 09:55 PM
Musclechuck Assembly Setting Rings keithet General Routing 2 03-29-2014 01:52 AM
Help with RF waves and glue setting time Bradleytavares Tools and Woodworking 0 03-19-2012 10:51 AM
What Is Draft Printer Setting? nathanplane Lobby 3 10-20-2009 01:25 AM
