Craftsman 1/2" collet - Router Forums
post #1 of 4 (permalink) Old 01-05-2017, 01:04 PM Thread Starter
Default Craftsman 1/2" collet
I have a Craftsman router mod. 320.17542. It has a 1/4" collet and a 1/2" collet. When I use the half inch collet I have a great deal of difficulty getting the collet to release the bit. I found that in order to release the bit from the collet I have to remove the collet and bit from the router, place them into my arbor press and push on the end of the bit to release the collet sleeve from the nut portion. Is this a common problem? Is there a replacement collet with a better design?
The quarter inch collet is an assembly that self- releases the bit, the half inch collet is simply a nut and loose tapered sleeve.
jimmiler is offline
post #2 of 4 (permalink) Old 01-05-2017, 04:47 PM
Most of the newer ones will loosen and then the nut tightens again and once you unscrew to loose again it comes out but some of the old are like you describe. I don't know if there is a cure for it.
post #3 of 4 (permalink) Old 01-06-2017, 09:15 AM
MEBCWD's Avatar
The 1/2" collet probably needs to be put together correctly. It should work just like the 1/4" collet and the collet probably needs to be pressed into the nut. usually the collet is held at an angle and pushed into the nut and clicks into place. It might also need to be de-bured.
MEBCWD is online now
post #4 of 4 (permalink) Old 01-06-2017, 10:21 PM
williamm's Avatar
I agree with Mike.
I had the same issue and used my bench vise and two blocks of wood to squeeze the collet into the nut.
williamm is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Adapt Craftsman to 1/2" collet Jalon7 Router Bits - Types and Usage 1 11-07-2012 08:42 PM
Craftsman Quickrout 1/2" collet adapter lwbox CNC Routing 7 05-01-2011 09:56 PM
Craftsman 315.17460 -- 1/2" collet possible? Stan in Oregon General Routing 1 10-28-2010 02:05 PM
Need 1/2" Collet for Craftsman Router redaws General Routing 4 02-09-2009 07:04 PM
