Freud FT2000e Switch problems - Router Forums
 1Likes
  • 1 Post By MYB506
post #1 of 5 (permalink) Old 02-09-2017, 09:07 PM Thread Starter
Default Freud FT2000e Switch problems
I have had this router since new and it has been great ....But, since last year or so the switch is becoming a PIA.
The switches on these routers are fully enclosed and really fun to put back together. I have had mine out and apart probably 5-7 times in the last couple years... The reason is that somehow this sealed unit is letting one little piece of sawdust in and of course it rests between the contacts ..
I'm on the verge of potting the whole switch in dielectric silicone grease but before I go that route I thought I would ask of anyone else has a solution...
Thanks in Advance
G Vavra
PS I have this mounted mostly full time on my table....
kimosawboy is offline
post #2 of 5 (permalink) Old 02-10-2017, 08:00 AM
First Name: Mark
I have never had a problem with my switch but then I don't use. I leave it on all the time and have it plugged into a receptacle with a switch mounted on the front of the table. If you only use it in the table like I do, putting an external switch on the table will be a lot less work.
tooler2 likes this.
MYB506 is offline
post #3 of 5 (permalink) Old 02-10-2017, 11:46 AM
Can you figure out where the dust is leaking in from? Maybe a little silicone sealant would stop that. If you never took it out of the table I would say do something like Mark did or wire it direct and bypass the switch and use an auxiliary.
post #4 of 5 (permalink) Old 02-11-2017, 01:27 PM
I had a similar issue with mine. I called tech support & even though they were bought out, the technician suggested that I try to blow it out with compressed air. I did and it worked fine after that. Mine too is always mounted.
IRestore is offline
post #5 of 5 (permalink) Old 02-11-2017, 07:48 PM
That will clear it for now Jim but if dust got in once, chances are good it will again unless you can figure out why and stop it.
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 08:33 PM
Bosch 1615EVS switch problems cbdeajr Table-mounted Routing 4 11-02-2015 08:13 AM
Freud FT2000E router just stopped running Jake Brain General Routing 8 05-21-2013 07:33 PM
Freud 2000E Starting/Speed Problems Milt & Carol Lane General Routing 33 05-04-2013 08:37 PM
Freud FT2000e for table router KonaJohn Table-mounted Routing 7 05-13-2009 02:57 AM
