Fireplace Mantel Routing Question - Router Forums
 13Likes
  • 3 Post By Cherryville Chuck
  • 2 Post By sunnybob
  • 4 Post By vchiarelli
  • 1 Post By boogalee
  • 1 Post By Stick486
  • 2 Post By MEBCWD
post #1 of 10 (permalink) Old 02-11-2017, 09:19 AM Thread Starter
oldhudson49's Avatar
First Name: Berry
Default Fireplace Mantel Routing Question
Over the past few months I've been remodeling our lower level. We had a gas fireplace roughed in. I've tiled it and now want to make a mantel. I have a
6' x 9" x 2" piece of maple that's been air drying for years.
I want to route a 2" radius Roman Ogee profile on 3 sides (face and both ends). My router is a Bosch 1617 EVS PK and I have a Kreg table. I typically try to route profile with a router table but this stock is so large and heavy that I'm thinking I should clamp the stock down and use portable routing. If I hold the router in my hand I'm worried about tear-out on the ends. And either way I'm worried about burning.
I will make several passes.
So what tips/suggestions/thoughts etc. can you old pros toss me? Thanks for reading.
oldhudson49 is offline
post #2 of 10 (permalink) Old 02-11-2017, 10:07 AM
see if any of this helps...
File Type: pdf Routing for Beginners - Lesson - 3.pdf (856.1 KB, 43 views)
Stick486 is offline
post #3 of 10 (permalink) Old 02-11-2017, 12:07 PM
Berry on the corners where you are worried about tear out rout them first, just nibbling away slowly in a climb cut direction. I try to anchor the router hand firmly against the piece to resist the climb cutting forces the router produces and swing the router in gently with my other hand. An alternate method is to clamp another piece of wood at those ends and the clamped piece will protect the corner if it is in good firm contact with it.
post #4 of 10 (permalink) Old 02-11-2017, 03:42 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
that would be one hell of a cut with a handheld.
I would use a router table and featherboards, and extension support trestle at both ends.
Care in preparation will pay off bigtime.
Its also possible on a table to make the cut in two or three passes, just by moving the fence back each time. which will help to reduce tear out.
MEBCWD and jj777746 like this.
sunnybob is offline
post #5 of 10 (permalink) Old 02-11-2017, 04:32 PM
If you are referring to the cut I described Bob I've done it many times. Remember that when going handheld the bit is not trapped in any way so if it does start climb cutting the bit just pushes the router away from the work. Feather boards won't make any difference in regard to tear out and narrow progressive cuts don't always prevent it either. If the grain happens to run at an angle inward at the corner it's possible to rip a sizable chunk out of it. The piece of wood he describes is one I wouldn't want to take a chance on tearing out as it would be very expensive to replace.
post #6 of 10 (permalink) Old 02-11-2017, 04:55 PM
vchiarelli's Avatar
First Name: Vince
Bob, that piece is 6 feet long and would be pretty heavy - you'd need a fairly large table or some other way of supporting that length without it tipping. Handheld, multiple light passes doing the ends first, then the long side is the way I'd go.
vchiarelli is offline
post #7 of 10 (permalink) Old 02-12-2017, 01:28 PM
TenGees's Avatar
First Name: Paul
Correct me if I'm wrong but I think routing the end grain last helps.
TenGees is offline
post #8 of 10 (permalink) Old 02-12-2017, 01:36 PM
boogalee's Avatar
First Name: Al
boogalee is offline
post #9 of 10 (permalink) Old 02-12-2017, 03:08 PM
I like 1st...
better results more often...
TenGees likes this.
Stick486 is offline
post #10 of 10 (permalink) Old 02-12-2017, 03:35 PM
MEBCWD's Avatar
Screw two pieces on the back of the mantle blank at the ends, one so you start cutting before you get to the mantle and the other to backup the grain and prevent tear out when finishing the cut. The screw holes will be on the back and never be seen.
TenGees and oldhudson49 like this.
MEBCWD is offline
Routing Template Verlin Garrett Jigs and Fixtures 16 08-17-2019 09:12 PM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
Routing 101 Question rweerstra General Routing 1 09-21-2010 02:39 PM
Routing Techniques on a RT - Question with pictures cyber7 Table-mounted Routing 7 07-21-2010 07:04 AM
