Stuck collet - Router Forums
 4Likes
  • 2 Post By hawkeye10
  • 1 Post By Stick486
  • 1 Post By Cherryville Chuck
post #1 of 7 (permalink) Old 02-13-2017, 03:09 AM Thread Starter
Default Stuck collet
Hi I need some help.
I have a collet stuck in my router (ELUMOF177e) with a broken cutter protruding 10mm from it.
The lock nut is not attached to the router. It is possible to put a nut over the cutter and attach to the router thread which could assist in removal of the collet, however I have no idea of the thread size. Any ideas are welcome.
woodworktools is offline
post #2 of 7 (permalink) Old 02-13-2017, 04:37 AM
hawkeye10's Avatar
First Name: Don
I would think that the router bit was installed to deep. In other words the bit is touching the bottom of the collet. I would put a good penetrating oil on there and let it set over night. The next day wearing safety glasses try knocking the bit down. It would only have to move a little to free it up.
Welcome and good luck.
neville9999 and jj777746 like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 7 (permalink) Old 02-13-2017, 07:01 AM
see if any of this helps...
neville9999 likes this.
post #4 of 7 (permalink) Old 02-13-2017, 11:01 AM
Lay the router on it's side and tap on the broken shaft with wrench or heavy screwdriver or something like those and keep rotating the arbor as you do it. It should loosen up within at least a few minutes.
post #5 of 7 (permalink) Old 02-13-2017, 12:31 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Nothing for me to say here, you guys have said it. N
neville9999 is offline
post #6 of 7 (permalink) Old 02-14-2017, 10:31 AM
Nickp's Avatar
First Name: Nick
Newton's Third Law of Motion...for every action there is an equal and opposite reaction...
Try putting a deep socket over the broken bit (not touching) but still fitting squarely to the edge of the router shaft...then tap the back of the socket sharply...this will try to drive the router away from the bit and the bit towards the hammer...
Nick
Nickp is online now
post #7 of 7 (permalink) Old 05-05-2017, 01:03 AM
To be honest, I have no idea of it.
icoinse15 is offline
1/4 Collet Adapter Stuck codycoyote General Routing 5 01-01-2016 11:28 AM
Hitachi KM12VC Collet Stuck Chilton88 General Routing 28 02-18-2015 05:28 AM
Need help with broken collet and stuck bit on a brand new Hitachi M12VE. kracken41 General Routing 33 12-20-2012 06:27 PM
Stuck collet on router - help tkm795 General Routing 5 01-13-2011 08:53 PM
