Another Router needed? - Router Forums
 27Likes
post #1 of 13 (permalink) Old 02-23-2017, 10:44 PM Thread Starter
First Name: BILL
Default Another Router needed?
Presently I have a Incra LS setup with the clean sweep and Jessem lift. I've got these mounted between two Festool MFT tables. I'm going to be using this setup to do dovetails and mainly small to medium size boxes. I'm wondering if I need a plunge router to go along with this setup or would the table mounted setup suffice?
I'm 73 years old and just looking at this for the pleasure and enjoyment of working with wood and producing some nice looking boxes.
Putttn is offline
post #2 of 13 (permalink) Old 02-23-2017, 11:05 PM
furboo's Avatar
First Name: Rob
Bill, "need" is all relative. I have a similar setup (minus the MFT tables), with a PC 7518 in the table and a separate Bosch 1617 for plunging and free-hand stuff. But if I didn't have the PC, I wouldn't hesitate to use the Bosch in the table. I just didn't want to spend the time installing/uninstalling the Bosch in the table. I also got the PC at a great price. You might have more patience than me. I would try one router for a while, that can do both (like the Bosch), and see how it goes.
Rob
furboo is offline
post #3 of 13 (permalink) Old 02-24-2017, 12:13 AM
For general use at a reasonable price, you just can't beat the Bosch 1617 EVSPK kit. It has both the fixed and plunge bases, goes for about $220 and occasionally, $20 less on sale. You can take the router in and out of the table as needed, although eventually you're likely to buy another router body so you don't have to take the router in and out. Most lifts fit the Bosch, but not necessarily all, so you have to check.
Not long ago, there was a discussion of using a miter bit (45 degree cut) on the table for making perfect corners for boxes. If I were making boxes, I'd give that method a good try. Harry Sinclair started the discussion. You can visit his page (HarrySin) to locate the string.
This is a great hobby. Do you have a table saw yet?
DesertRatTom is online now
post #4 of 13 (permalink) Old 02-24-2017, 12:46 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
You can never have enough routers!
I started this hobby on my retirement a couple years ago. I love the table router, I think its the best machine I have ever owned.
But then I wanted a router to fit to a sled for flattening small pieces.
And then I couldnt be bothered to unbolt the router from the sled to make other cuts.
And then, and then, (you can see where this is going by now cant you?)
I now own 5 routers, 3 bought used, and am a very happy person.
sunnybob is offline
post #5 of 13 (permalink) Old 02-24-2017, 05:18 AM
RainMan 2.0's Avatar
Bill I wouldn't hesitate to add a plunge router to your collection . You can't take your savings with you , so spend it before your grandchildren do it for you
Ok ,I never insulate
RainMan 2.0 is online now
post #6 of 13 (permalink) Old 02-24-2017, 06:30 AM
Daikusan's Avatar
Country: Japan
First Name: Steve
Bill, Have you signed up for the Triton Giveaway yet?
Workmanship is not perfection; it is how well you can cover your mistakes.
Daikusan is offline
post #7 of 13 (permalink) Old 02-24-2017, 12:00 PM
I'm busy doing some cupboard doors that are ply with solid wood banding and I'm adding a finger pull recess on the band on one end. So I currently have 2 routers in two tables, one with a flush trim bit, another with the bit for the finger pull, plus another one handheld with a roundover bit in it. I could get by with one router but I would constantly be changing back and forth and thrying to match up the roundover and finger pull to match previously done doors. So it isn't necessarily about need as much as want in order to keep the job more enjoyable.
thomas1389 likes this.
post #8 of 13 (permalink) Old 02-24-2017, 12:23 PM
You really do need at least one more, minimum!
MT Stringer and RainMan 2.0 like this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #9 of 13 (permalink) Old 02-24-2017, 01:03 PM
First Name: Earl
Is 5 more than 1??
greenacres2 is offline
post #10 of 13 (permalink) Old 02-24-2017, 01:24 PM
hawkeye10's Avatar
First Name: Don
I would get a router that has through the top height adjustment. Having this is so nice. Here is a link to one example but other companies make them.
Bosch 1617EVSTB 2-1-4 HP Fixed-Base Electronic Router and Router Table Base
MT Stringer likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Router bits needed for Leigh Dovetail Jig D4R Llewellyn New Member Introductions 11 08-13-2012 03:04 AM
Router Table Advice Needed cvn72 Starting Off 11 07-31-2012 08:30 AM
