Bosch POF 1200 AE Router collet issue - Router Forums
 3Likes
  • 2 Post By Cherryville Chuck
  • 1 Post By MEBCWD
post #1 of 7 (permalink) Old 03-06-2017, 04:27 PM Thread Starter
Default Bosch POF 1200 AE Router collet issue
Hi all,
I have the Bosch 060326A170 POF 1200 AE Router and I'm surprised & annoyed to say that the manual does not tell you how to change the collet. Despite coming with 3 of them (the 1/4, 6 and 8).
Default installed is the 8, but I need to swop out the collet to the 1/4 for a keyhole bit I have.
I removed the `nut` from the machine, but I cannot remove the cylinder (apologies if my terms are not right, i am a newcomer to woodworking). I have tried to pull it directly out but it won't budge and I cannot see a way of unscrewing it (not even sure that's how you remove it)
Have I done wrong by removing the `nut`? I must say this process is not intuitive at all, all help would be greatly appreciated!! Did a search on the forum but couldn't find any posts quite like my issue.
thanks!
BluePotato is offline
post #2 of 7 (permalink) Old 03-06-2017, 05:22 PM
Semipro's Avatar
First Name: John_*
Terminology
You have a nut and what you call a cylinder is the collet.
Never tighten down without a bit in the collet,never install a bit so that it bottoms out,
From your picture the collet is stuck in the router you need to tap on it lightly it has to come out. Look at the other collets that you have so you can get a idea what the one stuck looks like
Thank You John
Semipro is online now
post #3 of 7 (permalink) Old 03-06-2017, 05:38 PM
In most new routers the collet nut should stay attached to the collet but they can come apart separately sometimes. According to the schematic I found you should have 3 separate collets and nuts, parts 661, 662, and 663.
post #4 of 7 (permalink) Old 03-06-2017, 08:04 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #5 of 7 (permalink) Old 03-07-2017, 05:36 AM Thread Starter
Wow, this may be the most helpful forum ever
Ok, so how and where exactly do I `tap` it out?
(And if anyone from Bosch is reading this, put this info in the manual!!!!)
post #6 of 7 (permalink) Old 03-07-2017, 08:46 AM
Lay the router on its side and using a small hardwood stick place it against the collet and tap it with a hammer lightly. Rotate the collet and tap again and keep doing that until it loosens. You can use a pin punch instead but don't hit it hard enough to dent the collet. Be very careful not to hit any threaded part.
roxanne562001 and BluePotato like this.
post #7 of 7 (permalink) Old 03-07-2017, 09:38 AM
MEBCWD's Avatar
Your collet should snap into the nut when it is out of the router. They should be snapped together before use. place the nut flat on you bench take the collet and put it into the nut and push until you hear a click. you may have to tilt the collet a little bit to get it to go into the nut.
Then you can screw the nut back on the router, insert the proper size bit and tighten the nut. When you loosen the nut to remove the bit the nut will pull the collet out of the shaft and loosen the bit. There may be a spot that the nut turns free then tightens again and this is okay and how your nut/collet should work. Continue loosening the nut and the collet will loosen and the bit can be taken out.
BluePotato likes this.
MEBCWD is online now
Ryobi RRT 1600-s or Bosch POF 1200 AE Dave_022 General Routing 16 01-19-2017 06:31 AM
offset router collet wrench for Bosch UncleJoe Table-mounted Routing 17 12-23-2014 01:51 PM
buying my first router - questions about Bosch router bases in a table achoox4 New Member Introductions 2 11-28-2012 04:10 PM
Broken Router Collet deanr Table-mounted Routing 12 10-26-2012 12:52 PM
bosch 1200 pof ae collet problem claytonjohnroby General Routing 6 08-23-2012 10:37 AM
