Need Help with Routing Recess - Router Forums
 23Likes
post #1 of 18 (permalink) Old 03-23-2017, 05:42 PM Thread Starter
Default Need Help with Routing Recess
I need to route recesses in some 1 x 2 pieces of hardwood.
Lets say 1/4" deep and 12" long.
What, in your opinion, is the fastest, most efficient and safest way to make 100 of these?
Thanks.
wscbg is offline
post #2 of 18 (permalink) Old 03-23-2017, 06:44 PM
Honored Member
First Name: pat
Glue 1/4" pieces onto a 1/2" slab. Would not rout.
harrysin, JOAT, MEBCWD and 3 others like this.
Quillman is offline
post #3 of 18 (permalink) Old 03-23-2017, 07:14 PM
Nickp's Avatar
First Name: Nick
Yup...1/4" pieces glued accordingly...
Not a router job...ganging a few together is likely to yield different depths and the routing/clamping could launch any of the pieces...too much hogging with a router bit...no good way to secure the base of the router. A sled above the pieces might work but you would need to find a way to secure the pieces together and have a backer board...too much tape/glue. You could use a sled and hog out an entire board's worth and then cut into strips...If yu do this you will need a bit ith cutters on the bottom and wide enough to be productive.
Probably not a table saw/dado blade job either...you would have to mount them onto a backer board securely enough to hold them together and create a single piece...
Not a jig saw job...would never get the clean edges on the flat between the 1/4" pieces...
Not a bandsaw job either...
Yup...1/4" pieces glued onto the long piece as Pat posted above...bunch of small clamps...maybe brads along with it depending on your application. You could also glue long 1/4" pieces onto a long board and then cut into strips to size...
's'all I got...
MEBCWD likes this.
Nick
Nickp is offline
post #4 of 18 (permalink) Old 03-23-2017, 07:45 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is online now
post #5 of 18 (permalink) Old 03-23-2017, 08:14 PM
Make friends with someone that has a CNC machine and has some free time.
RainMan 2.0 likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #6 of 18 (permalink) Old 03-23-2017, 09:13 PM
Welcome WSCBG. I would add to the first couple of posts that it would be veeerry slow going to do 100 and therefore probably not cost efficient.
post #7 of 18 (permalink) Old 03-23-2017, 10:00 PM
Thanks.
welcome to the forums...
I agree w/ Quillman and Nick...
it would be stronger to glue because you will have more control ove the grain...
harrysin and MEBCWD like this.
post #8 of 18 (permalink) Old 03-23-2017, 10:19 PM
Gluing 1/4 pieces will be very strong, and you will have a cross grain connection. Do them 4-6 at a time and cut them apart with a table saw. You will need a couple of boards clamped to the end of 3-6 pieces to keep ends aligned. Wax these so the glue doesn't stick to the alignment boards. Clamp the pieces together without glue. If they are going to be exactly 2 inches across, you'll either have to put blade width spacers in place to separate the 12 inch boards, or use something like 2 1/8th strips that you cut down later.
I don't see any really efficient way to do this. It will take some hand work no matter what.
harrysin and jj777746 like this.
post #9 of 18 (permalink) Old 03-24-2017, 01:14 AM Thread Starter
Thanks for all the replies. But...
Gluing is not an option.
It must be one solid piece.
Any other ideas?
Thanks again.
wscbg is offline
post #10 of 18 (permalink) Old 03-24-2017, 03:57 AM
table saw sled and dado blade...
MEBCWD, Shop guy and jj777746 like this.
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
old person new to routing in wood sailer670 New Member Introductions 12 12-13-2014 07:31 PM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
Routing a recess for a patch jimshine Router Bits - Types and Usage 12 02-01-2013 07:50 PM
Routing recess for mirror. Ski Jig? doomi Jigs and Fixtures 3 01-04-2013 05:42 PM
