is a portable router powerful enough for cutting slots on side of ipe boards? - Router Forums
 14Likes
post #1 of 28 (permalink) Old 03-25-2017, 02:21 PM Thread Starter
Default is a portable router powerful enough for cutting slots on side of ipe boards?
I am a newbie to routers, and would like to know if a portable router is powerful enough to cut slots on the side of an ipe board which is a pretty hard wood.
I've seen instructions to use a 3-wing slot cutter (5/32" width and 1/2" depth).
Was considering buying a portable 1.25HP router such as the DeWalt DWP611 router.
tico is offline
post #2 of 28 (permalink) Old 03-25-2017, 02:56 PM
MT Stringer's Avatar
Welcome to the forum.
Are you talking about cutting a slot on the edge of the material or on the flat side?
How many feet in length are you talking about?
The router bit may dull before the router gives out.
More info please.
RainMan 2.0 likes this.
MT Stringer is offline
post #3 of 28 (permalink) Old 03-25-2017, 04:00 PM Thread Starter
this is for a deck, slots will be on the edge, a few inches long every 16" (enough to insert a clip to screw the board on a joist).
So the slot does not have to go the full length of the board.
I would have liked to paste a URL of a video showing what I want to do - but looks like I need more than 10 posts ;-(
Google for "how to groove square edge deck boards" on the fastenmaster web site.
You'll find an example of video showing how these small cuts are done but was not sure about the type of router used (again this is for a very hard exotic wood)
Can hand held routers be used for this kind of job?
Thanks!
http://www.fastenmaster.com/blog/det...ck-boards.html
tico is offline
post #4 of 28 (permalink) Old 03-25-2017, 04:09 PM
kp91's Avatar
First Name: Doug
Sounds like a job for a biscuit jointer
harrysin and Herb Stoops like this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 28 (permalink) Old 03-25-2017, 04:58 PM
The biscuit joiner would work but a slot cutter should also do the job but the DW611 is the absolute minimum size router I would use. About 2 hp would be better like a Bosch 1617 or Hitachi M12VC.
Danman1957 likes this.
post #6 of 28 (permalink) Old 03-25-2017, 05:27 PM
1st off machining Ipe is tough on tooling... go w/ the Freud 4-wing cut slot cutter...
also... in this case, more is better...
I'd like to suggest A Bosch 1617EVS instead... or even the 1617EVSPK...
way better move... VOE...
WHY I LIKE BOSCH...
2nd to none CS and support that's absolutely painless...
They respect us, the consumer...
they make tools that are real work horses...
they make tools that last a very long time... decades of hard heavy use..
they make tools that protect my bottom line...
I think/believe Bosch to be an outstanding company that offers outstanding products...
do yourself a huge favor down road and get a Bosch 1617EVSPK...
Factory Reconditioned Bosch 1617EVS-RT 12 Amp 2.25 HP Fixed-Base Router
Saving some money now just may cost you more down the road.
Bosch is the only one that scores high on all categories and is as close as a phone and your mail box...
Have a look at CPO outlets for reconditioned. I have never heard a true negative word about them. Their service or Bosch
Stick486 is offline
post #7 of 28 (permalink) Old 03-25-2017, 07:12 PM
I have a pair of the 1617's. I used one to cut raised panel doors. That is a big cutter...almost 3 1/2 inches in diameter. I ran the router at it slowest speed. She moaned and groaned but she did a good job!
Name:	2013-10-15 19.52.25.jpg
Name:	2013-10-15 21.44.19.jpg
Name:	Bosch 1617 Router Kit.jpg
File Type: pdf Bosch 1617 EVSPK Router Combo Kit Description -small.pdf (442.3 KB, 74 views)
post #8 of 28 (permalink) Old 03-25-2017, 07:14 PM Thread Starter
ok looks like 1.25hp is going to be a bit challenging as I was suspecting.
I liked them because they are small and lightweight (~4lb).
Moving up to 2hp is going to mean using something over 7lb. So a bit more work to move it around on the deck (I'll have to cut quite a bit of slots) but the recon models are not that much more expensive.
The Bosch 1617b definitely looks like a nice router!
I could not find any Freud 4-wing slot cutter that is 5/32" (only up to 1/4"). All those slot cutters I have seen that cut 5/32" have only 3 wings.
Another option for me would be to buy pre-grooved boards, which adds about $500 to the cost of the boards for a project of my size.
tico is offline
post #9 of 28 (permalink) Old 03-25-2017, 07:22 PM
I must have bought a different type of deck board. The ones I bought are tongue and groove. Buy a box of clips and screws and go to town. Simply put a screw and clip into each joist. noting shows above the deck.
http://www.routerforums.com/show-n-t...-part-4-a.html
Go to about post #18 where I talk about the playhouse and the deck.
post #10 of 28 (permalink) Old 03-25-2017, 09:30 PM
First Name: JT (Jim)
Simply put, Ipe is extremely abrasive even on carbide tooling. Horsepower helps (and is needed) so long as the cutting tool stays sharp, then you just produce lots of heat.
MT Stringer likes this.
subtleaccents is offline
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Portable router table kodena Table-mounted Routing 6 10-25-2012 09:51 AM
new router has side to side movement whilst plunging??? matey General Routing 2 11-11-2005 02:09 PM
