Rounding End Grain Box Joints - Router Forums
 14Likes
  • 1 Post By gmercer_48083
  • 9 Post By Cherryville Chuck
  • 2 Post By sunnybob
  • 1 Post By hawkeye10
post #1 of 8 (permalink) Old 03-31-2017, 12:05 PM Thread Starter
First Name: Gary
Default Rounding End Grain Box Joints
I want to use a 3/8" rounding bit with bearing to round over the end grain of a box. The box is pine with 1/2" box joints, and ready to route. I realize I must make skim cuts to sneak up on it's final shape. I am planning to hand route using a guide fence.
My question is, should I adjust the depth of the bit to final depth, then sneak up by changing the fence setting until the guide bearing contacts?
Should I start out by having the guide bearing contact the box and sneak up on the final cut by adjusting the depth?
Which method would produce the smoothest cut, and why?
chessnut2 likes this.
gmercer_48083 is offline
post #2 of 8 (permalink) Old 03-31-2017, 12:33 PM
Easiest is to increase the depth a little for the final cut. You don't need the fence, let the bearing do the work. You'll know after the first one if you need to do it in multiple stages. Clamp a board over the end where the bit will exit or you could blow the grain out there. Have the board's edge flush along the top and the end of the board flush (or close) with the end.
TWheels, Gene Howe, JFPNCM and 6 others like this.
post #3 of 8 (permalink) Old 03-31-2017, 11:26 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
What Charles says... The most important part is to have more wood at the far end so the cutter keeps going after the box is done. make sure its clamped TIGHT.
With the sacrificial wood in place, I would cut about an 1/8" at a time.
Herb Stoops and jj777746 like this.
sunnybob is offline
post #4 of 8 (permalink) Old 04-01-2017, 06:12 AM
hawkeye10's Avatar
First Name: Don
Gary have you done a test on another board to be sure what it will look like? You will need to know how far to let the bit out so all the corners will be the same.
TWheels likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 8 (permalink) Old 04-01-2017, 08:22 AM Thread Starter
First Name: Gary
If I understand, you are saying to use a well clamped sacrificial board against exit edge to prevent tear out. Keep the bearing against the edge with each cut. Lower the router bit slightly vertically with each pass to sneak up on the final cut.
I just wanted to find out what is meant in every ones opinion how to handle shallow passes. It seems that lowering the bit (exposing more) with each pass will produce a cleaner cut.
I have noticed the round over bit I am going to use has a shear angle of about 5 degrees, which should throw the chips in the direction of the router as well as outward. The shear angle could contribute to a nasty kick back if routing in the wrong direction. Any other thoughts?
Cherryville Chuck likes this.
post #6 of 8 (permalink) Old 04-01-2017, 09:39 AM
chessnut2's Avatar
Excellent question, Gary. I've never really known the best way. Thanks for posting.
chessnut2 is offline
post #7 of 8 (permalink) Old 04-01-2017, 12:08 PM
I think you have it covered. Feed direction handheld is left to right but if you were feeding the wrong way it wouldn't kick back. It would just try to pull you with it and the bit would start skittering along the surface. There will always be resistance when you are feeding the right way.
post #8 of 8 (permalink) Old 04-01-2017, 02:52 PM
TwoSkies57's Avatar
The bearing itself pretty much can serve as your fence, just adjust the bit. Without a bearing, set the bit, and adjust the fence. Either way, final pass needs to be minimal. Often just a little additional pressure is enough to clean things up nicely
Skipper the Penguin
TwoSkies57 is offline
Gluing End Grain patlaw Tools and Woodworking 6 03-24-2016 03:52 PM
Incra Ultra How-To (Box Joints + Other Stuff) Nickbee Show N' Tell 17 06-22-2009 12:42 PM
Best wood/ grain hiding technique for jewelry box top rstermer The Finishing Touch 3 05-03-2008 11:57 AM
My 1st Box w/inlayed joints (Build Along)? Nickbee Show N' Tell 53 11-27-2007 12:56 PM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
