T Style TS Fence Question - Router Forums
 8Likes
  • 4 Post By Herb Stoops
  • 3 Post By Cherryville Chuck
  • 1 Post By RainMan 2.0
post #1 of 7 (permalink) Old 04-01-2017, 08:42 AM Thread Starter
Contributor of the Month
Default T Style TS Fence Question
Do you push the handle all the way down to lock or just snug it?
JIMMIEM is offline
post #2 of 7 (permalink) Old 04-01-2017, 09:36 AM
RainMan 2.0's Avatar
I have an Excalibur fence similar to the Bies fence and I lock it all the way down . For some reason I like to leave the handle up when not in use . Not sure if that's important, but it's just something that I do
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 7 (permalink) Old 04-01-2017, 10:05 AM
I do both,don't even think about it.
JFPNCM, Shop guy, Oakwerks and 1 others like this.
Herb Stoops is online now
post #4 of 7 (permalink) Old 04-01-2017, 10:54 AM
First Name: Ray
Lock down, it will not move, esp. when cutting sheet goods like 3/4" plyw'd or MDF....
Ray Newman is offline
post #5 of 7 (permalink) Old 04-01-2017, 11:55 AM
I only snug mine and I've never had it move. The unifence adjusts similarly to others by adjusting a nut at either end of the "T". You can vary the tension the lock handle puts on the guide rail by how much you adjust those nuts. You can go from barely holding enough to barely needing to move the handle down to get it tight enough. So the point of all that is that if you have it adjusted tighter then pushing the handle all the way down could be putting a lot of stress on the rail and the clamp and for no reason. You only need to have it tight enough to keep the fence from moving during a cut.
DaninVan, Roy Drake and tomp913 like this.
post #6 of 7 (permalink) Old 04-01-2017, 12:35 PM
Your obviously don't have OCD though?
Herb Stoops likes this.
post #7 of 7 (permalink) Old 04-04-2017, 11:22 AM
MikeMa's Avatar
Lock it down all the way. I had it come loose once while running dados. (handle got knocked while moving pieces around) Found it after I ruined 4 pieces. I was very lucky to not have had a kickback. If the saw is on while using the fence, it should be locked down all the way, no question at all. This is absolutely a safety issue if it isn't locked down completely.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
New toys: Pro Fence & Jessem Mite R Slide 2bigfeet Table-mounted Routing 1 09-15-2011 01:13 AM
A Poor Man's adjustable Positioning Fence Stefang Table-mounted Routing 8 02-26-2010 03:22 AM
Introduction & 1st question (table saw router fence recs) david coburn Tools and Woodworking 4 05-27-2009 09:05 AM
Newbee question on router fence boxer Table-mounted Routing 2 02-05-2008 11:01 AM
question on Oak Park spacer fence old folks Table-mounted Routing 2 08-01-2007 12:14 PM
