Router wrenches. - Router Forums
 18Likes
post #1 of 29 (permalink) Old 04-06-2017, 05:48 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Router wrenches.
I have a PC 690 in my router table and it has through the top height adjustment which I love. I hate the wrenches that come with this router and all routers. I use a crescent wrench on the top nut and have an offset wrench for the bottom. The wrench is a piece of you know what. If I bought a Muscle Chuck I think they are around $50 and I would need two. One for 1/4" and one for 1/2" router bits. I could be wrong about needing two. So does any one have a good fix for this?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 29 (permalink) Old 04-06-2017, 06:43 AM
I use Muscle chucks on both of my router tables and use the 1/2"-1/4" reducers in both machines,the Bosch 1617 and PC 7500 3.5 hp.
The Bosch is the only one that has the above the table height adjustment, the PC I can only get the chuck above table height about 3/8".
Herb Stoops is online now
post #3 of 29 (permalink) Old 04-06-2017, 08:55 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Like Herb., I use a 1/2" to 1/4" reducer supplied by Derosa Engineering, the maker of the fabulous Musclechuck which only requires about a half turn of a 4mm ball ended Allen key, available everywhere in many styles.
JFPNCM and Herb Stoops like this.
Harry
harrysin is offline
post #4 of 29 (permalink) Old 04-06-2017, 08:08 PM
Terry Q's Avatar
Have you considered offset wrenches? I know Rockler sells a set for Porter cable routers, I'm sure there are others
as well.
Sent from my iPad using Tapatalk
Terry Q is offline
post #5 of 29 (permalink) Old 04-06-2017, 09:49 PM
JFPNCM's Avatar
First Name: Jon
Agree with Herb and Harry, the Musclechuck is the answer. Just buy one with the reducer collet.
Herb Stoops likes this.
Jon
JFPNCM is offline
post #6 of 29 (permalink) Old 04-08-2017, 11:02 AM
I have the 690 router in a Bench Dog lift which doesn't quite allow using the standard (flat) wrench on the spindle nut without going in on an angle. I bought one of the offset (bent) wrenches and it solved that problem but presented another one. The wrench needs to be held at the correct height in order to stay on the hex, but it's easy to let it move while you're trying to get the other wrench on and lined up. Came up with the idea of cutting a piece of plywood in a "C" shape - outside to match the outside of the wrench and inside a clearance with the hex flats. Drill a couple of holes in the wrench and attach the plywood to the bottom of the wrench. When changing bits, the bottom of the plywood shim can sit on the motor housing at the correct height and not slip below the hex. Should only take a couple of minutes to make one, may give that a try.
tomp913 is offline
post #7 of 29 (permalink) Old 04-08-2017, 01:38 PM
My wife says this is why I never get anything done - too easily distracted.
Didn't take too long - except I was going to get fancy and tap holes in the wrench and come up through the ply with fl hd bolts. That idea lasted until I snapped a 6-32 tap off in the wrench. So I went back to plan "A", short SM screws with the point filed off on the back side.
Works OK, the plywood shim sits on top of the router face and the metal lines up with the hex so it doesn't drop down off the hex.
Now back to the scheduled project................
kp91, chessnut2, TenGees and 1 others like this.
tomp913 is offline
post #8 of 29 (permalink) Old 04-08-2017, 06:56 PM
roofner's Avatar
First Name: Gary
I have mussel chuck 1.2 and white side 1/4 reducer works on my bosch at a better price works great.
roofner is offline
post #9 of 29 (permalink) Old 04-08-2017, 07:37 PM
Before I got the Muscle chuck, I was using the offset wrench along with the straight wrench . I could not get the collet nut up like you show and the offset wrench was gowing up the Aluminum twist lock insert in the table .I was afraid that it would do permanent damage such that the plastic plate would not fit, I decided to just go with the muscle chuck . After I used the muscle chuck, for awhile, I decided to get another for the bosch in the other table
harrysin and JFPNCM like this.
post #10 of 29 (permalink) Old 04-08-2017, 07:52 PM
@Herb Stoops
I don't remember if the larger opening was one of the features that led me to pick the Bench Dog lift way back or if I just lucked out. You can use the straight wrench with the lift as shown on their web site but the wrench has to be angled in and I was always getting them tangled. The offset wrench was a good solution except trying to keep it at the right height so it didn't slip off the hex - the plywood shim seems to have taken care of that.
Bench Dog Products: Pro-Lift
tomp913 is offline
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
router wrenches wanted whelffer General Routing 3 09-17-2010 01:27 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
