Speed Tape by Fast Cap. Yuk!!! - Router Forums
 12Likes
post #1 of 23 (permalink) Old 04-09-2017, 01:12 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Speed Tape by Fast Cap. Yuk!!!
So far I hate it but maybe I am doing something wrong. I was routing some 3" circles with my CRB7 and I had a heck of a time getting the tape off the circle. I tried acetone, Mineral spirits, heat, and a scraper. I finally got it off but it was no fun. So have any of you guys used this stuff? If so what do you think?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 23 (permalink) Old 04-09-2017, 01:18 PM
kp91's Avatar
First Name: Doug
Don,
I think it is designed for permanent applications. If you aren't happy, let them know. They are very customer focused, and always looking to improve their product or instructions.
oldhudson49 likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 23 (permalink) Old 04-09-2017, 01:55 PM Thread Starter
hawkeye10's Avatar
First Name: Don
I forgot who but I was this being used for wood working on You Tube. Fast Cap also has a short video on their site and they are using it for template routing.
post #4 of 23 (permalink) Old 04-09-2017, 04:03 PM
JOAT's Avatar
First Name: Theo
Haven't used that particular brand, but have tried double stick tape, rubber cement, what all. And didn't like any of them, mainly because of the time required to clean residue off my wood. And that's when I started tacking my pieces together. I drill pilot holes thru my masters, then use thin nails about 1 1/ 4" long (my masters are all 1" thick), tack the piece to be routed. Rout, pop the master loose, viola, got a piece routed. Yes, there are nail holes. No biggie, because I design almost all my stuff so the nail holes are inside, or otherwise hidden. On the very, very, rare occasion when the nail holes will be in view, no problem, I simply drill the pilot holes in a decorative pattern, and the nail holes are now part of the design. Been using nails for I don't know how many years, and I am very satisfied with the results.
And, if you think it's just a quick fix, well, it is, but it is also very accurate. There is a utube video out there somewhere of a old, professional, harp maker, the concert harp kind. And he nails his pattern down. I was doing it before then, but it was nice to know that I'm not the only one doing it. Some people use screws to hold their material, but I much prefer nailing.
OK, found the video. The nailing is at 3 min. He does a nice job of wiping excess glue too. lol I'm saving the video to watch again. And again. And again.
TenGees likes this.
JOAT is online now
post #5 of 23 (permalink) Old 04-09-2017, 04:36 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Theo I can't tack what I am routing. I am routing different size small circles. There is a 1/4" hole in the center so I am using my M Power CBR7 to rout out the circles.
JFPNCM, Danman1957 and TenGees like this.
post #6 of 23 (permalink) Old 04-09-2017, 05:08 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Theo thanks for the video. They are some real wood workers. If you are a wood worker you will enjoy watching it.
I want a flush trim bit like his. WOW
TenGees likes this.
post #7 of 23 (permalink) Old 04-09-2017, 06:08 PM
A fellow wood worker uses hot glue which he raves about. Template pops right off and no residue. He just dotted it on in strategic places. If any sticks, he heats it a little and rubs it off.
I used to use the tape you are using and it is the stickiest doubleback tape I have ever used , it sticks to everything and hard to get off. Like you I used every solvent known to man and still left a residoo doo.
I went to the tape that this guy on the router forum was selling and it is really good. Can't give you a source as I wiped out all my PM's today trying to save them to a folder.
It is really thin and holds very well comes off with no residue.
RainMan 2.0 likes this.
Herb Stoops is online now
post #8 of 23 (permalink) Old 04-09-2017, 07:21 PM
kp91's Avatar
First Name: Doug
That ain't a flush trim bit, it is a finger eraser... Shapers are probably the scariest tool out there in a wood shop in my opinion.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #9 of 23 (permalink) Old 04-09-2017, 08:05 PM
JOAT's Avatar
First Name: Theo
OK, looked up that thingy and saw how it works. Then saw what you're making. If I were making a base like that, there would be no hole in the center, and I'd put the nail holes on the bottom.
But I can't figure out where the tape comes in. Unless you're doing something the company video isn't showing.
In the hopefully near future I will be making at 6-7 sizes of circles, truck wheels, from just over 2 1/2" to probably just under 12". I've got one circle laid out on 1/4" graph paper. I will glue this to 1/2" plywood, drill the center, rough cut the largest circle, put a bolt thru the hole, then spin it with a drill, and use a hand belt sander to bring it down to the largest size. I'll drill pilot holes in that, tack it to a rough cut circle, rout the bottom circle. Then glue the bottom circle to another rough cut circle, rout that, which will give me a 1" thick perfectly round master, which will be drilled for pilot holes. Rough cut a circle, tack the master to it, rout, and a perfectly round work piece, turned to put the holes on the bottom.
Repeat through all the size circles (wheels) I will need.
Now, where's the tape come in?
JOAT is online now
post #10 of 23 (permalink) Old 04-10-2017, 04:54 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Theo your right I could use nails but the 1/4" hole has got to be there because I use a 1/4" dowel to attach the base to the cross. Also I am locating the base in the same spot on the substrate (MDF) to help with tearout. I really don't know if I need to do that but that is my theory.
Above-surface CNC Router Speed Too Fast drone6251 CNC Routing 4 08-29-2016 12:39 PM
My New Favorite Tape Measure DonkeyHody Tools and Woodworking 36 12-07-2015 12:15 PM
Testing Peachtree double-sided tape Gaffboat Tools and Woodworking 22 11-17-2014 09:05 PM
Speed Controllers and soft start motors kevinrf General Routing 13 11-26-2012 01:47 PM
