first timer - Router Forums
post #1 of 9 (permalink) Old 04-12-2005, 07:19 PM Thread Starter
Default first timer
still in the box-help need some first time information on how to set up router in table, so confused. will check back tomarrow>
chach is offline
post #2 of 9 (permalink) Old 04-12-2005, 07:25 PM
Bob N's Avatar
First Name: Bob
The first order of business is to attach the router to the plate and then the plate to the table.
If you can be more specific I'm sure we can give even more assistance.
BTW.... Welcome to the Router Forum. Good folks found here always willing to lend a helping hand and enjoy a common hobby.
Bob N is offline
post #3 of 9 (permalink) Old 04-12-2005, 07:54 PM
reible's Avatar
Welcome!
Yea I think we might need a bit more information to get you going.... lots of types of tables and routers out there.
I see you have an old farm house in need of molding so getting a router and table should help you out. My GGGrandfather settled in Dodge Co back in the 1850's. I still have relatives living there on orginal land.... and still farming/milking.
Ed
reible is offline
post #4 of 9 (permalink) Old 04-12-2005, 09:01 PM
-Sam-'s Avatar
First Name: Sam
Question
Hi Chach,
Yeah, just give us some more information on what you have. Do you have a router table? If so, which one?
Sam
Retired Forum Moderator
Refer a friend to RouterForums.com!
-Sam- is offline
post #5 of 9 (permalink) Old 04-12-2005, 11:17 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hi chach, welcome to the forum. I don't want to sound like a copy cat, but we do need more info on what you have. Let us know, and the advice will flow.
Dave
the "Doctor"
Dave
the "Doctor"
Dr.Zook is offline
post #6 of 9 (permalink) Old 04-13-2005, 01:43 AM
steveo's Avatar
First Name: Steve
Welcome aboard!!!
Good to have another HD man around from my favorite state in which to have fun.
Steveo
steveo is offline
post #7 of 9 (permalink) Old 04-23-2005, 08:00 AM Thread Starter
thanks for all the replies. i have a SKIL 1 3/4 H.P ROUTER mounted to a VERMONT AMERICA router table. 2 problems, cant seem to keep the router from loosening off the table, and is the router bit supose to have slight play in it. the bit moves side to side with about 1/16 inch of play. thanks . chach
chach is offline
post #8 of 9 (permalink) Old 04-23-2005, 08:30 AM
First Name: Richard
Default loose router
Hi: from the info you gave, the router bit should have no side to side play.
When mounting the bit, the bit should not go all the way to the bottom of the collet, pull it up about 1/16" and tighten it up. You don't indicate how the router is mounted into the table. Is it held in by screwing the router
in from the table top? Or is the router clamped into the bottom of the table? I would suggest that you check the router bit when you mount it inthe router to see if the bit is loose or the collet moves sideways due to worn bearings. I would not run it with the play you indicate, it may not be safe. Hope this helps.. Welcome to the Forum Woodnut65
Woodnut65 is offline
post #9 of 9 (permalink) Old 04-23-2005, 08:43 AM Thread Starter
thanks, very helpful info. i will keep plugging in information and will try all suggestions
will let you know how i'm progressing.
chach is offline
Old Timer "Newbie" jdphill New Member Introductions 21 12-10-2008 09:48 PM
Finishing painted signs, first timer Help please ColoChris The Finishing Touch 13 11-12-2007 10:42 AM
1st timer borderat36 New Member Introductions 4 05-01-2006 09:23 AM
First Timer ryan.s New Member Introductions 5 03-17-2005 06:27 PM
