Router bit speed! - Router Forums
 1Likes
  • 1 Post By kp91
post #1 of 6 (permalink) Old 05-02-2017, 08:31 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Router bit speed!
I have been routing with my new Whiteside 1/4" spiral flush trim bit. At full speed "23,000 RPM" it seemed to not be cutting all that good. Don't get me wrong it doing okay I just thought it might do better at a slower speed. So I slowed it down to around 18,000 or 20,000 RPM. I seemed to get a better cut. My question is do you play around with the router speeds to get a better cut?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 6 (permalink) Old 05-02-2017, 08:34 AM
yes...
post #3 of 6 (permalink) Old 05-02-2017, 09:05 AM
CharleyL's Avatar
First Name: Charley
Some things do cut better at slower speeds. Some do better at higher speeds. I also slow my router speeds when using any bit larger than 3/4". The larger the bit, the slower I run it for safety more than cutting quality. I have a large Freud Shaker style panel raising bit that I worry about when I run it at 11,000 rpm. I would never dare to run it any faster, and I'm glad that I bought a good brand name bit for doing this. I don;t think I have the nerves to run a large Chinese bit at even this slow speed.
Charley
Central North Carolina
CharleyL is offline
post #4 of 6 (permalink) Old 05-02-2017, 04:32 PM Thread Starter
hawkeye10's Avatar
First Name: Don
I was just wondering if any one else adjusted their speed. When routing with the WS bit I just thought it could do better.
post #5 of 6 (permalink) Old 05-02-2017, 05:30 PM
kp91's Avatar
First Name: Doug
Feedrate and bit speed can go hand in hand. You might have been feeding the stock into the bit a little slow for full speed.
My old 690 is single speed, and you can see a difference in cut quality on some patterns, especially red oak, when you slow down for inside corners
MEBCWD likes this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #6 of 6 (permalink) Old 05-02-2017, 06:17 PM
Honored Member
First Name: pat
If the router shakes or if the cutter is out of balance, slow it down.
I suspect that one of the 2 was your problem.
A 1/4 (short, <3/4" long) cutter should be run to the max.
Quillman is offline
Router Bit Speed Selwyn Senior General Routing 12 02-24-2014 04:39 AM
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-19-2014 11:41 PM
Router speed vs bit speed Bar clamp General Routing 11 01-27-2011 09:20 PM
Variable Speed Plunge Router Application MJCookSr Table-mounted Routing 2 10-22-2010 05:54 AM
