Flush Trim Cutter with Down Shear - Bottom Bearing - Router Forums
 1Likes
post #1 of 15 (permalink) Old 05-02-2017, 02:37 PM Thread Starter
Default Flush Trim Cutter with Down Shear - Bottom Bearing
Hi
Is a Flush Trim Cutter with Down Shear and Bottom Bearing suitable for profile routing on a router table?
Regards
John
John Charnock is offline
post #2 of 15 (permalink) Old 05-02-2017, 03:43 PM
kp91's Avatar
First Name: Doug
That will work!
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 15 (permalink) Old 05-02-2017, 04:00 PM
yup...
post #4 of 15 (permalink) Old 05-02-2017, 06:12 PM
Honored Member
First Name: pat
I'd use a straight solid carbide, not twisted. It might pull the sample off your template.
A straight has no shear vectors.
Ed3443 likes this.
Quillman is offline
post #5 of 15 (permalink) Old 05-03-2017, 01:54 AM Thread Starter
I had never thought of straight vs twisted. Do you know where can I find more information on the comparisons?
J
post #6 of 15 (permalink) Old 05-03-2017, 06:05 AM
kp91's Avatar
First Name: Doug
A straight, two flute carbide bit has two cutting edges running parallel (or really close to parallel) to tlhe body of the bit.
Spiral bits are machined like a drill bit, with the flutes wrapped around the bit. They can be upspiral or downspiral, depending if they pull stock up to the collet or push it away from the collet
http://www.woodmagazine.com/woodwork...ing/spiral-bit
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #7 of 15 (permalink) Old 05-03-2017, 12:12 PM
MEBCWD's Avatar
John if the bit is listed as a down-cut bit it will try to lift the part off the table because it is designed to push chips away from the collet. If you do use a down-cut bit it would be best to use feather boards to hold the part down for safety.
MEBCWD is offline
post #8 of 15 (permalink) Old 05-03-2017, 03:44 PM Thread Starter
I am a bit confused now, what is best and of the safest for use on a router table for profiling?
Regards
John
post #9 of 15 (permalink) Old 05-03-2017, 03:47 PM Thread Starter
This is the bit
Axcaliber Flush Trim Cutter with Down Shear - Bottom Bearing - Trimming - Router Cutters - Routing - Power Tool Accessories - Accessories | Axminster Tools & Machinery
Is it a spiral bit?
John
post #10 of 15 (permalink) Old 05-03-2017, 04:17 PM
MEBCWD's Avatar
John that is a down shear bit but it is not a spiral bit. It will try to push the part up from the table, remember the router is upside down in the table. The more material you try to take at one time the more pressure will be generated. If you make lite passes and use good push blocks you should be okay, just don't try to over feed the bit or it might cause enough rise you might have problems.
MEBCWD is offline
What Do You Do With Worn Flush Trim Bits JIMMIEM Router Bits - Types and Usage 14 11-14-2016 10:24 AM
Flush Trim Bit - How to determine which one? tcoldewey Router Bits - Types and Usage 2 03-01-2009 05:57 PM
Flush Trim Bit Top Bearing vs. Bottom Bearing steveD Router Bits - Types and Usage 14 12-22-2008 01:36 PM
Flush trim bit not flush RuggerJoe Router Bits - Types and Usage 8 03-19-2008 12:57 PM
Flush Trim Bit? cbsjoez1935 Router Bits - Types and Usage 5 07-28-2007 11:35 AM
