Laminate counter with oak edge - Router Forums
post #1 of 14 (permalink) Old 01-03-2009, 02:58 PM Thread Starter
First Name: Keith
Default Laminate counter with oak edge
Hi guys,
I am going to replace the laminate on my countertops since the current laminate is lifting all over the place.
My question is the edge has a decorative oak trim but then the front face is then laminated as well. The edge looks like ogee to me. I have two sheets of laminate coming in at 90 degrees to each other in the z direction. To put it another way; if your monitor is the countertop laminate sheet then I have another laminate sheet coming directly out at you on edge. How do I trim the edges of the laminates? Do I just go at the edge with the ogee bit?
My concern is that I will be cutting one of the laminate sheets correctly with the rotation on the bit but the other one is going to be cut against the rotation of the bit.
Does this make sense? Am I overthinking this??
Here's a picture of the edge:
Name:	edge section.jpg
kefjens is offline
post #2 of 14 (permalink) Old 01-04-2009, 08:28 AM
Honored Member
harrysin's Avatar
First Name: Harry
Could you post a close up shot of the corner, without flash, I'm sure this will make it easier for you to get answers.
Harry
harrysin is offline
post #3 of 14 (permalink) Old 01-04-2009, 08:50 AM
Gene Howe's Avatar
First Name: Gene
If you are referring to the inside corner, by the DW, I can't see a problem with changing direction. There will be a problem with the ogee bit not conforming to the 90 deg. angle, assuming you'll be laying the laminate in one piece.
If you were to use a 45 deg. (or another angle) bit, simple rasping, filing and scraping would complete the corner. You could do it after an ogee cut but, it would be a great deal more difficult, IMO.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 14 (permalink) Old 01-04-2009, 01:50 PM
Pagan Wizard's Avatar
First Name: N/A
My suggestion would be to laminate your new edge before making the miter cut. This would give you your 90 inside angle.
Pagan Wizard is offline
post #5 of 14 (permalink) Old 01-04-2009, 04:21 PM Thread Starter
First Name: Keith
I'm wasn't worried too much about the inside corners. I think whatever I come up with for the straight edges will apply to the corners.
I've attached a close-up of the edge itself. My problem is when the overhang from the laminates from the countertop and front edge come together in two perpendicular planes.
Thanks for your thoughts!
kefjens is offline
post #6 of 14 (permalink) Old 01-06-2009, 01:31 PM
Ghidrah's Avatar
First Name: Ronald
I appologize if I've misunderstood the problem, but if not, Under the conditions given, (you can't remove and or replace the bead). I would build a plywood mock-up matching the laminate surface area inside the decorative bead, test the pattern on the counter for conformation and when satisfied secure the lam to the template and route.
Ghidrah is offline
post #7 of 14 (permalink) Old 01-06-2009, 05:51 PM Thread Starter
First Name: Keith
Ghidrah that is a spectacular idea! Next time I'll think outside the box a little. Thanks!
kefjens is offline
post #8 of 14 (permalink) Old 01-07-2009, 12:59 AM
Keith, you should have no problems routing this edge. You might have to do a little hand trimming to get your bit to the start position, but it will cut the laminate on both surfaces as long as the bit makes contact.
Did you get my PM?
post #9 of 14 (permalink) Old 01-07-2009, 01:59 AM
Honored Member
harrysin's Avatar
First Name: Harry
Why couldn't the bead be removed, the laminate fitted and trimmed and then re-fit or replace the bead?
Harry
harrysin is offline
post #10 of 14 (permalink) Old 01-07-2009, 01:14 PM Thread Starter
First Name: Keith
Mike, I got your initial PM. I had to post enough to be able to respond. Now I'm over the 10 limit so I'm good to go.
I think I'll make the mock-up and try it first to see what happens. I'm just a bit concerned about chipping the laminate by trimming both edges at the same time.
Thanks for the help.
kefjens is offline
laminate counter top lyoncub Starting Off 2 01-10-2008 11:57 PM
Help with veneer plywood edge profile magicman22 General Routing 12 10-10-2007 04:13 PM
Groove in edge of curved piece imrichb Router Bits - Types and Usage 5 07-06-2007 03:03 PM
Silktree Natural Edge BernieW Woodturning and Lathes 10 10-13-2006 11:48 PM
