Plywood/dado router-bit question - Router Forums
post #1 of 12 (permalink) Old 04-18-2005, 08:44 AM Thread Starter
Default Plywood/dado router-bit question
I'm building a simple piece for my shop out of CDX plywood, which is just under 3/4" thick. I want to use dados for some of the joints, but my 3/4" router bit will cut the dado just a hair too big, leaving me with a sloppy joint.
I've read that there are special router bits for undersized plywood. I don't want to spend much money on these bits. Any suggestions? I know 3/4" plywood thicknesses can vary quite a bit.
- Toolfreak
Toolfreak is offline
post #2 of 12 (permalink) Old 04-18-2005, 09:34 AM
Bob N's Avatar
First Name: Bob
- Toolfreak
I believe you can find exactly what you are looking for at Holbren which is one of our sponser's. Here is the link:
https://holbren.com/product_info.php...aae270a3984f2b
I ordered this set and have been very happy with them and they do not break the bank either
Bob N is offline
post #3 of 12 (permalink) Old 04-18-2005, 09:39 AM
First Name: jerry
You can use a smaller bit,move the fence and make another pass.
jerry
jerrymayfield is offline
post #4 of 12 (permalink) Old 04-18-2005, 10:55 AM
The Router Guys
BobandRick's Avatar
Check out my last router tip, I have a simple jig that will cut with a smaller router bit. check this link
Rick and Bob
The Router Guys
On January 17th, 2020 Dad passed Away at the age of 87 and I will miss him very much. If anyone is interested there is a memories website https://memories.routerworkshop.com/
BobandRick is offline
post #5 of 12 (permalink) Old 04-18-2005, 12:58 PM Thread Starter
Default Wow!
Wow!! I just ordered the set. These bits are cheap!!! I've never used this brand. I know they sponsor the show, but how are they really to work with??
- Toolfreak
post #6 of 12 (permalink) Old 04-18-2005, 01:40 PM
Bob N's Avatar
First Name: Bob
- Toolfreak
I have found them to be quite satisfactory. When I ordered I purchased 2 sets (I believe they had some kind of special or was trying to balance the freight... can't remember for sure), but for the money they are a good value IMHO.
Cheers
Bob N is offline
post #7 of 12 (permalink) Old 04-18-2005, 06:22 PM
SSc
- Toolfreak
I have this set....ordered when starting some cabinets for the wifes laundry room....was a bit skeptical at first but for cabinet grade, sanded both sides plywood...these bits work great...fit was so good hardly needed glue....of course I did glue them on final assembly
one thing I did do....I very slightly sanded the edge that is inserted into the dado...just enough to get rid of the "fuzz" ....making assembly much easier...
dunno how these bits would hold up under production use....but for the home shop they should do you quite nice...
SSc is offline
post #8 of 12 (permalink) Old 04-18-2005, 10:15 PM
steveo's Avatar
First Name: Steve
If you have quite a few inches of dado to do, pop for the "plywood bit". Its easier than screwing with a jig. Been there, done that.
steveo
steveo is online now
post #9 of 12 (permalink) Old 04-19-2005, 09:05 AM Thread Starter
Default yep
steveo
Yeah -- I just want to be able to clamp a straight-edge to the plywood and run my router against it.
- Toolfreak
post #10 of 12 (permalink) Old 05-02-2005, 09:14 PM
GoonMan's Avatar
First Name: Randy
I received my Holbren Dado bits today. Those are nice. Thanks for the tip.
GoonMan is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 09:47 AM
