Real Climb Cuts - Router Forums
 11Likes
  • 2 Post By MikeMa
  • 2 Post By Semipro
  • 1 Post By Herb Stoops
  • 2 Post By Quillman
  • 3 Post By Seldonman
  • 1 Post By Biagio
post #1 of 10 (permalink) Old 06-05-2017, 10:27 AM Thread Starter
Seldonman's Avatar
Default Real Climb Cuts
No this is not a problem about routing the wrong way or climb cutting. Rather, I am having a problem routing a 1/4 inch groove so I can install 1/4inch plywood for the bottom of drawers I am making. I have had this problem on two different router tables with separate lifts so it is not the lift or the table. The problem is that I am using a two flute 1/4" shank bit and it wants to lift up as I make the cut. That is, say I start off at 1/4 inch depth by the time I am at the end, say 15 inches, the depth is not 3/8th or greater. Is this an inherent problem or am I doing something wrong?
Jim
Seldonman is offline
post #2 of 10 (permalink) Old 06-05-2017, 10:34 AM
MikeMa's Avatar
Make sure when you are putting you bit in the router you are not bottoming it out. This could keep the bit from being secured. Also make sure your router's depth adjustment is locked.
Shop guy and Herb Stoops like this.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #3 of 10 (permalink) Old 06-05-2017, 10:35 AM
Semipro's Avatar
First Name: John_*
Are you sure that the 1/4" bit is tight not climbing up out of the collet?
Semipro is online now
post #4 of 10 (permalink) Old 06-05-2017, 10:43 AM
Is your lift locked down good? Or is it the bit that is creeping out of the collet? Are you using a metric 6mm bit in a 1/4" collet,or vice versa? Is this the same bit in both router set ups, might try a different bit if it is,or mike the bit and see what diam the shank is, sometimes the shanks are a little undersize on the off shore bits.
MEBCWD likes this.
Herb Stoops is online now
post #5 of 10 (permalink) Old 06-05-2017, 10:52 AM
I had a problem like this with a Rockler lift, which relied on a compressed rubber washer to hold the height adjustment. I suggest you also drop a half inch grommet in the collet and bottom the shank on that. Bottoming in the collet itself is not a good idea. What kind of lift are you using?
post #6 of 10 (permalink) Old 06-05-2017, 11:14 AM
Honored Member
First Name: pat
Use 1/4 slotter. They're built radially, will not clog.
Very efficient cutting, like a saw blade
MEBCWD and Herb Stoops like this.
Quillman is offline
post #7 of 10 (permalink) Old 06-05-2017, 03:34 PM
I just talked to the guy who bought that lift you speak of, and he said he just tightened the lock nut on the locking cam of the Rockler lift and he hasn't had a problem with it.
Don't you think a 1/2" hi grommet is a little much in the collet? I would think more like a 1/8" thick would be better. IMHO
I think Pat has the best solution, the right bit for the right operation. I make the same mistake ,I get in the mind set that one particular bit will do all kinds of operations,when there are bits that will do specific operations better.
post #8 of 10 (permalink) Old 06-05-2017, 05:32 PM Thread Starter
Seldonman's Avatar
By George, I think you are correct and that I am using the incorrect bit. Now if only there was a holiday coming up where grown children gave gifts to their Dads then I could ask for a slot cutter!
post #9 of 10 (permalink) Old 06-06-2017, 06:52 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Until your kids get the hint, use your table saw as a slot cutter.
Wildwood is offline
post #10 of 10 (permalink) Old 06-06-2017, 08:09 AM
First Name: Biagio
This problem is by no means rare, and has featured on this forum before. I had an issue with a 1600W Ryobi, where the two-flute bit would wiggle out no matter what I did (was not bottomed out, either). The bit was good on three other routers, two of the same make but different models. New collet made no difference. The agents were able to replicate the problem, replaced the whole machine, but the problem persisted. Must have been a dud batch of spindles.
The router is lying unused, hopefully until I visit some geography where a musclechuck or equivalent is reasonably affordable (our exchange rate is putrid there was a time when it was close to 2 US$ to one Rand, now Rand 12.70 to the greenback).
+ 1 for using a slot cutter for that particular purpose.
Herb Stoops likes this.
Biagio is offline
angled dado cuts for shelves sawdustter1 New Member Introductions 8 04-10-2014 01:02 PM
Compound Miter Cuts For Picture Frames Jerry Bowen Tools and Woodworking 7 02-26-2013 02:01 PM
Jerry's latest observation on accurate cross cuts Jerry Bowen Tools and Woodworking 32 10-15-2012 10:34 PM
first real attempt newwoodworker Pyrography and Carving 1 10-28-2010 10:33 AM
Real time RSSI routerssi Lobby 1 02-11-2010 07:44 PM
