Question for corners... - Router Forums
 8Likes
post #1 of 13 (permalink) Old 06-18-2017, 08:47 PM Thread Starter
USMCGRUNT's Avatar
First Name: Ryan
Default Question for corners...
Hello all,
I am building my first swing cradle and had a question in regards to routing a 1/4" round over along the edge.
The plans I am going off of call for a 1/4" round over. My (newb) question is, how can I router the 1/4" round over profile where the neck meets at? I have attached a close up photo. And will I have any problems when I go around the corners of the pieces?
Normally I would think that those area would get some type of corner radius with a flush bit, but these plans call for the round over around all the edges of these pieces.
Any suggestions would be much appreciated. And just an fyi if needed, I have Bosch hand held, plunge, and palm routers. I also have a Milwaukee mounted to a routing table.
Thanks!!
USMCGRUNT is offline
post #2 of 13 (permalink) Old 06-18-2017, 09:01 PM
Bob Adams's Avatar
First Name: Bob
Ryan, (glad you changed your name from n/a) the only issue with a round over in that corner would be the size of the bearing. You can test the cut by holding the bit up to the corner to see if it is going to cut. If the bearing interferes go to a smaller bearing. Thanks for your service!
RainMan 2.0 likes this.
Bob Adams is offline
post #3 of 13 (permalink) Old 06-18-2017, 09:02 PM
kp91's Avatar
First Name: Doug
First off, your shop would definitely pass inspection! Very clean.
The bit will follow the corner just fine, but the round over will not be "perfect". I would recommend making a sample to practice on out of MDF scrap to see what it would look like. If you are fine with it, the round over is all you need.
If you don't like it, you have a few options. You can blend it by hand, or you can stop the round over an inch or so from the corner. It will be up to you what looks best. A final option is a solid pilot router bit, they can get into tighter corners, but can leave burn marks.
Herb Stoops likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 13 (permalink) Old 06-18-2017, 09:47 PM Thread Starter
USMCGRUNT's Avatar
First Name: Ryan
Bob, no problem at all on the name change, I am glad that it was pointed out to me. And you are most welcome, thank you!!
KP91, I like to try and keep it as clean as possible until the wife decides she is going to randomly "set" things out in the garage. After the cradle (and baby are born) I actually want to redesign it with much needed storage space.
Thank you both for the very fast replies and the suggestions. I think I will make a small template and try it with a couple different bearing sizes. I can definitely see the standard size bearing not being able to make that trip around without hitting the other side. I that doesn't work, then I may just have to soften that area by hand.
Thanks!!
kp91 and Bob Adams like this.
post #5 of 13 (permalink) Old 06-19-2017, 12:54 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
This is a pilot round over bit. you can see how close to the corner you can get.
http://woodworking.formeremortals.ne...81-700x394.jpg
As long as you keep the piece moving you should not get any burn marks, but even then, slight burns can be sanded out.
sunnybob is online now
post #6 of 13 (permalink) Old 06-19-2017, 01:15 AM
Hi Ryan and glad to have you aboard. As mentioned the round over will look a little off at the junction. Another option is to not cut quite to a relatively square corner and use a sanding drum to finish the cut and create a radiused corner. The rounder over bit would follow the radiused corner perfectly.
post #7 of 13 (permalink) Old 06-19-2017, 02:24 AM
TWheels's Avatar
Ryan, welcome!
May I suggest another solution. Use the standard roundover bit to the corners, then when the bearing gets in the way, switch to a bit of the same radius that has no bearing. It would be test to use an edge guide or template guide and template guide to avoid cutting into the body of the neck. Depending on the source these bits are known as radius grooving or point cutting roundover bits. but they all look like the picture below and are generally used to cut internal grooves, not edge roundovers. I know these its with a 1/4 inch radius are sold by Amana and, for a few $ less, by MLCS
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #8 of 13 (permalink) Old 06-19-2017, 04:17 AM
JOAT's Avatar
First Name: Theo
These guy should have answered all your questions. Me, I stopped using roundover bits long ago, I just use my ROS now. For what I do works great.
I've seen some nice cradles, but just never have been able to really like them - ever since I realized just how fast a baby will outgrow one. Then they either set around gathering dust, or you pass it on to someone, or sell it - the cradle, not the baby. MY choice of new baby thing is a rocking chair. Rock the kid to sleep, put him/her in their bed, go back to the rocker and relax for awhile. And you can use it for years. Rockers are uni too, suitable for men or women. My vote for your next project is - wait for it - a ROCKING CHAIR.
kp91 likes this.
JOAT is offline
post #9 of 13 (permalink) Old 06-19-2017, 09:20 AM
Garyk's Avatar
First Name: Gary
All good suggestions. If you choose to use Chucks idea of the sanding drum use caution as those things can sometimes work faster than your hands can. Being old school I would get close to the corners and finish it off with a wood rasp and/or carving chisels. I can control the progress better that way. And thank you for your service.
USN 61-65.
kp91 likes this.
Garyk is offline
post #10 of 13 (permalink) Old 06-19-2017, 01:02 PM
rwl7532's Avatar
First Name: Ralph
Or add to each corner in question a piece that has a radius. Contrasting wood as an accent as well.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
Hello with a router fence question nevertoosafe New Member Introductions 9 11-02-2014 02:22 PM
Another Question From Jerry Jerry Bowen Tools and Woodworking 19 02-18-2014 11:36 AM
Question About This Forum Jerry Bowen Tools and Woodworking 4 03-30-2012 09:46 AM
