Work Bench - Router Forums
 7Likes
post #1 of 16 (permalink) Old 06-19-2017, 05:34 PM Thread Starter
KhalTom's Avatar
Default Work Bench
I have a pretty large workbench. At one time 30 years ago it was the base for a pedestal style bed. There were two halves, each halve had 2 drawers in each ofnthem, so they fit together in a square which a the main bed sat on. It was custom made for me and i used it as a bed for years. Problem was, im 6'7 and it put the bed really high. As the yaers passed and matreeses became thicker and thicker it just made my bed higher and higher...i could still get in it, but i had to lift my leg up onto it if you know what i mean. Well tthem came my marriage to a woman who is 5 ft tall....yeah...at first i made a step. She got tired of the xtra space the step ate up, so i pulled pedestal out and made a new one out of 2x4 , making it a more normal height.
Thats a long back story. Sorry.
Anyway i took the old pedestal out and stacked one side on the othwr amd it is the perfect table height. Ive been using it as my work table ever since. So you get an idea, i have an old door on top of it as a table top and it just about fits perfect.
So im now going to make this officaially my work bench. Kept the two drawers on bottom, and am turning the two on top into shelf space and a place to hold my drills and sanders.
Im chuxking tje door amd am putting a big piece of 3/4" ply on top. I want to cover it with formica or laminate, and i also want to install T tracks.
FINALLY MY QUESTION
DO i put on the laminate firat, covwr the entire thing, then router it for the T Tracks? Or do i put in the T tracks and put the laminate on after?
Im also installing a an electric plug on top.
Any thoughts appreciated
Sent from my SM-G955U using Tapatalk
KhalTom is offline
post #2 of 16 (permalink) Old 06-19-2017, 05:42 PM
TwoSkies57's Avatar
Put that outlet somewhere it can't get dripped into, dropped on, dropped into, knicked, dinged or otherwise assaulted by any number of the many things that will find their way to it.
If you must laminate, laminate first, then dado your tracks into place....
just another couple cents worth, I'd forgo the laminate..the 3/4 ply will look like a work top after a couple years, I'm not so sure about a laminated top???
Skipper the Penguin
TwoSkies57 is offline
post #3 of 16 (permalink) Old 06-19-2017, 05:45 PM Thread Starter
KhalTom's Avatar
Ive gone back and forth on the laminate. Ive seen some on youtube that look nice, and im thinkiy would be easier to clean but ive had the same thought.
KhalTom is offline
post #4 of 16 (permalink) Old 06-19-2017, 05:50 PM
TwoSkies57's Avatar
I don't know this from experience, but I would think that with a laminate you lose a good bit of friction when clamping down onto it...might just be 6 of one, half dozen of the other.
Skipper the Penguin
post #5 of 16 (permalink) Old 06-19-2017, 06:32 PM
MT Stringer's Avatar
FINALLY MY QUESTION
Tom- just thinking about it...T Track will take up at least half of the thickness of the plywood if you don't double it to make it 1 1/2 inches thick. I say before you do anything, do some testing to see how the screws will old the track when you have something clamped and pulling against the screws.
Good luck. Post some pics of your bench when you have time.
TwoSkies57 and jj777746 like this.
MT Stringer is online now
post #6 of 16 (permalink) Old 06-19-2017, 06:34 PM Thread Starter
KhalTom's Avatar
I was wondering about that too...
MT Stringer likes this.
KhalTom is offline
post #7 of 16 (permalink) Old 06-19-2017, 06:41 PM
Not knowing how your frame is built and how the plywood will sit on top of it, you could attach a 3 inch wide strip underneath in the areas where it wouldn't get in the way of mounting the top to the frame. Just some extra beef in the area under and to either side of where the track will be dadoed. Glue and a few clamps should do just fine until the glue dries. Or use screws, then remove them after everything is dry.
post #8 of 16 (permalink) Old 06-19-2017, 07:25 PM
I built a table from 5/8 melamine a few years ago and dadoed it for t track which only left 1/4" of meat under the tracks but I lined the grooves up with stringers under them and the table worked perfectly and was always flat. After 4 years of using it I left it with my SIL when I moved home from northern Alberta. They are moving back home so I just dismantled it to avoid having to pack it back and it was still flat.
The current table's fence just clamps on and is also a single thickness with lam on top but there is no lam on the underside of the overhang so I've had no issues with slippage. I glued the lam onto mdf and the lam lasts longer than the mdf but it's not a big deal either way. Both are fairly slippery and the mdf would go quite a while too.
post #9 of 16 (permalink) Old 06-20-2017, 08:37 AM
I'd love to see a picture of how it looks now. (and after)
197761 is offline
post #10 of 16 (permalink) Old 06-20-2017, 09:58 AM
Double up on the top with either another layer of ply or MDF. I'd also put some 1x2 or 3 straight boards (trusses) under the table to help it stay flat. Double layer will also give a better grip for the dog holes. If you use MDF, make sure you pre drill for any screws you install into it. It splits and tears out easily. This double will be heavy, but that helps with table stability. If you use the plywood for the top, wax, wax, wax it. Glue drips from squeeze out leaves raised areas bumpy, and waxed surfaces are easier to clean off
If you want a renewable top, which is my preference, put a 1/4 inch thick high density fiber board (Masonite) on top and wax the heck out of it to keep glue drippings from sticking. Use some 1x around the edges set high enough to hold the replacable top in position and protect the edges. Maybe counter sink screws on the corners to hold it down. Don't glue it down.
Get a roll of brown craft paper and or a roll of 18 inch butcher paper (white) to work on when gluing or staning. It will protect the top from inevitable spills, drips, etc.
Put the outlet on the side of the legs, or mount under one edge of the bench top so the outlets face out. Be sure to use a cable clamp of some sort for the wire, and I'd use at least 12 gauge cable.
Assemble the whole thing, then drill the 3/4 inch dog holes. Later, you can mount the top on a custom cabinet and put in shelves and drawers as you wish. I put doors on all my cabinets, it helps keep the sawdust out.
The double ply structure is also strong enough to mount an end vise, and maybe even a side vise in the future. I would never put T-track in a workbench, it isn't that useful. You can get clamps that fit in the dog holes, add an end vise to use with dog holes to hold pieces, or mount the T-track on a separate piece of ply and pull it out when needed. You may find you don't want the T-track built into the table, so waiting to install them is your safe bet.
JFPNCM, tomp913 and CharlesWebster like this.
DesertRatTom is online now
Dunnage Work Bench Dziadek1 Show N' Tell 23 03-23-2015 10:19 PM
Work bench RainMan 2.0 Project Plans and How To 22 01-08-2015 09:30 PM
Suggestions for a new bench please darsev Workshop Showroom 32 11-17-2014 04:43 AM
Two section work bench Check twice! Show N' Tell 15 09-04-2008 12:08 AM
Bench sized powertools JTsteelblu Tools and Woodworking 3 10-13-2004 01:31 PM
