help needed - Router Forums
 12Likes
post #1 of 12 (permalink) Old 08-11-2017, 09:58 AM Thread Starter
First Name: David
Default help needed
Hi there, I'm making a coat rack but I find when I rout the edges some are fine and some have like scuff marks on them what the router leaves, anyone tell me what I'm doing wrong ?
its mainly on the corner, but as I say the other corner ok so I musty be doing something wrong
thanks
David ....
Davidrd is offline
post #2 of 12 (permalink) Old 08-11-2017, 10:15 AM
bit is getting dull..
clean your bit...
climb cut the scuffed corners...
vindaloo, Danman1957 and TenGees like this.
Stick486 is offline
post #3 of 12 (permalink) Old 08-11-2017, 11:35 AM Thread Starter
First Name: David
thanks for your help mate, I did wonder if that was my problem dull cutter,
and thanks for the links, there very interesting.....
Davidrd is offline
post #4 of 12 (permalink) Old 08-11-2017, 11:55 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Also, if you slow down around corners the wood gets overheated and burns. But that can be sanded off carefully.
vindaloo likes this.
sunnybob is online now
post #5 of 12 (permalink) Old 08-11-2017, 01:24 PM
Part of the problem is the end grain. Going one way the bit is moving away from it and shears the grain. On the next corner its biting into the grain and tearing some of it off. If this is the case then it will be opposite corners that are scuffed. Like Stick said, a sharp bit and possibly climb cutting it are about the only things that help.
post #6 of 12 (permalink) Old 08-11-2017, 04:39 PM
Your cool, it is just the way routers react to grain direction. Good answers above.
jj777746 likes this.
Herb Stoops is online now
post #7 of 12 (permalink) Old 08-12-2017, 07:15 AM Thread Starter
First Name: David
thanks guys for all the help
Davidrd is offline
post #8 of 12 (permalink) Old 08-12-2017, 08:46 AM
hawkeye10's Avatar
First Name: Don
As Stick said above use a sharp router bit. The cheap bits out there may not be sharp when new. I found out this the hard way.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #9 of 12 (permalink) Old 08-12-2017, 09:13 AM
David, a Router Workshop rule which may help you is to cut across the grain, with the grain, across the grain and with the grain around your board. Trend Tool and Bit cleaner works great.
post #10 of 12 (permalink) Old 08-12-2017, 09:59 AM
First Name: frank
Davidrd,
First let me tell you, I loved the question. I think this may have helped me more than you. I am having the same issue on a different little project. But these are the answers that I needed. I have bought some new freud bits, but that did not help. I think the information to do the routing differently will help.
So sir, I hope this will help both of us. It is just amazing and disgusting to me how much Woodworking Knowledge, is contained on this forum.
Thanks again,
artman60 likes this.
Tagwatts is offline
Greetings /Help needed tennesseeheritage New Member Introductions 15 01-17-2016 10:16 AM
New to the forum, looking at buying whats needed to make my own stair nosing. fcat General Routing 21 01-16-2016 12:09 PM
DD34 manual needed IvanO New Member Introductions 3 02-27-2014 04:55 PM
Information needed for newbie Mickeyt General Routing 10 11-16-2012 02:21 AM
Router selection help needed robdunstan Table-mounted Routing 19 02-14-2008 03:37 PM
