Another Muscle Chuck question. - Router Forums
 9Likes
post #1 of 12 (permalink) Old 08-13-2017, 04:00 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Another Muscle Chuck question.
I Have a long 1/2" flush trim bit. Is it okay to run it down in the blades down in the MC? I need to get it down so the bearing will ride the template. It looks like it would be okay but I am not sure.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 12 (permalink) Old 08-13-2017, 04:45 PM
I had this dilemma one time and decided against it,in that the holding power of the chucks surface area is diminished tremendously and is relying on the chuck to clamp on the cutters which are soldered onto the tool. They weren't made for that type of pressure and might chip or damage or come loose in operation.
That said, I solved the problem with drilling a hole in a piece of plywood and clamping it on the router table to raise the feed of the stock up high enough to guide the bearing on the template.
JFPNCM and jj777746 like this.
Herb Stoops is online now
post #3 of 12 (permalink) Old 08-13-2017, 07:14 PM
Don, if you are using the router free hand you can easily make a thicker sub base plate and attach it with double sided tape for jobs like this.
post #4 of 12 (permalink) Old 08-13-2017, 09:58 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Mike I am only using it in my router table.
post #5 of 12 (permalink) Old 08-13-2017, 10:18 PM
As Herb suggested an auxiliary table top is the easy fix for table mounted height issues Don. It can be clamped in place or fastened with double sided tape. You will find this tip in many woodworking books to solve other problems too such as a bit that will not fit through your plates center hole or when using a tilting router motor for special cuts.
post #6 of 12 (permalink) Old 08-14-2017, 02:38 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
The first time that I came upon such a problem I purchased a bit similar to this one.
http://www.ebay.com.au/itm/NEW-1-2-I...%257Ciid%253A1
Herb Stoops and jj777746 like this.
Harry
harrysin is offline
post #7 of 12 (permalink) Old 08-14-2017, 07:55 AM Thread Starter
hawkeye10's Avatar
First Name: Don
[NEW] 1/2 Inch Shank Flush Trim Router Bit With End Bearing Woodworking Cutter
Harry I have thought about that but was looking for away to get around buying another bit. I think buying the one bit will solve the problem so that is not a big deal.
post #8 of 12 (permalink) Old 08-14-2017, 10:22 AM
harrysin's Avatar
First Name: Harry
There are cheaper ones, I'm sure mine was only about $A7.00 and is as good as some of my very expensive ones. Over the years I've bought one off bits that looked interesting and any that I have used on a regular basis I tend to purchase an expensive one. I haven't counted how many bits I have but I would guess at least 150. On occasions a particular shape can be obtained by using more than one bit.
Herb Stoops likes this.
Harry
harrysin is offline
post #9 of 12 (permalink) Old 08-14-2017, 11:46 AM
This is a common issue if you do much pattern routing so it pays to have a few different lengths of both flush trim and pattern bits. In the long run it's easier to have the bits than to have to monkey with spacers. Yonico/Precision Bits have fair decent quality bits for reasonable prices.
post #10 of 12 (permalink) Old 08-14-2017, 12:15 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Chuck Stick won't let me buy any more of those cheap bits.
Lathe chuck adapter wooden cross Woodturning and Lathes 5 06-15-2014 09:30 AM
Another Question From Jerry Jerry Bowen Tools and Woodworking 19 02-18-2014 11:36 AM
Newbie Question ajgraham General Routing 4 06-26-2013 07:39 PM
Rookie here, got a question wyatt earp New Member Introductions 6 07-18-2008 08:33 AM
