Single vs Variable Speed - Router Forums
 14Likes
post #1 of 24 (permalink) Old 09-07-2017, 07:58 PM Thread Starter
First Name: Matt
Default Single vs Variable Speed
Hello. My name is Matt from Toronto and I am new to the forum and woodworking. I am a very handy diy'er who wants to build cabinets for closet wardrobes and 'built ins', bookcases, etc.
I'm busy with family/career so I bought a Kreg bench top router table to save time. I also bought a barely used Ridgid TS3650 table saw. I found a Porter and Cable 690 Single speed router in my neighbourhood, used once.
I have been reading and watching YouTube and am now worrying that I should have purchased a Variable speed router. Should I have? I haven't drilled holes in my Kreg mounting plate just yet.
Is this just a case of Variable being 'nice to have, not necessary' ' or 'just get one'?
Thanks for your advice.
Matt
Sent from my SM-N910W8 using Tapatalk
mgarofolo is offline
post #2 of 24 (permalink) Old 09-07-2017, 08:02 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to router forum, Matt
If you only have one router variable speed would be the most ideal but you can do a lot of work with a Single speed
mgarofolo likes this.
Thank You John
Semipro is online now
post #3 of 24 (permalink) Old 09-07-2017, 08:07 PM Thread Starter
First Name: Matt
I should have mentioned that I also have a Bosch Colt Variable Speed. My concept was to have a 1/2 Collet table mounted router for 'heavy lifting' and a hand held for finish work on a larger work piece or simple round-over work.
post #4 of 24 (permalink) Old 09-07-2017, 08:20 PM
Hey, N/A; welcome!
There are 3rd party speed controllers on the market; others may have input as to whether they'll work for you.
The main reason for being able to control motor speed is to limit the tip speed on larger bits. Different species of wood react better at slower speeds as well.
https://www.wwgoa.com/video/router-bit-speeds-000313/
DaninVan is offline
post #5 of 24 (permalink) Old 09-07-2017, 08:26 PM
JOAT's Avatar
First Name: Theo
Well, depends on what you've got in part, and what you plan to do in part. Me, I've got 4 or 5 single speed routers, been using them for 20-30 years, and for what I use them for they do just what I need. So, for now at least, I have no plans to change.
JOAT is offline
post #6 of 24 (permalink) Old 09-07-2017, 08:29 PM
My apologies for the "N/A", Matt. I didn't remember seeing your name when I glanced back at the original post. *embarrassment*
DaninVan is offline
post #7 of 24 (permalink) Old 09-07-2017, 08:30 PM
kp91's Avatar
First Name: Doug
Single speed is fine. If you are going to make raised panel doors using a horizontal panel raising bit (3" diameter) you'll probably want a speed control to slow it down. Everything else should be fine. I have VS motors that rarely get adjusted down.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #8 of 24 (permalink) Old 09-07-2017, 09:43 PM
You're okay to 1.5 inch diameter bits. Larger than that you need to start slowing them down. 3.5" raised panel bits should be run at about 12,000 rpm. Like Dan said you can get an after market speed control as long as you don't have soft start but chances are you don't because they usually come with speed control too.
post #9 of 24 (permalink) Old 09-07-2017, 10:08 PM
Matt...
listen to DaninVan...
just go 3rd party speed control..
Stick486 is offline
post #10 of 24 (permalink) Old 09-07-2017, 10:10 PM
Hr. Matt...
some reading for you...
File Type: pdf Routing for Beginners - Lesson - 3.pdf (856.1 KB, 44 views)
File Type: pdf R5 Climb-Cutting Versus Chip-Cutting.pdf (176.1 KB, 52 views)
harrysin, lowracer and mgarofolo like this.
Stick486 is offline
PC 5182 Need help making variable speed work lorencharter General Routing 4 11-11-2011 09:05 AM
Question about variable vs single speed routers cseymour Sign Making 8 06-02-2011 10:33 AM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 04:10 PM
Bosch Colt...variable or single speed..? R69S Tools and Woodworking 10 01-15-2011 10:37 AM
adding a speed controller to a single speed router Sawatzky Table-mounted Routing 5 01-24-2009 08:49 AM
