Triton base - Router Forums
post #1 of 3 (permalink) Old 09-09-2017, 08:58 AM Thread Starter
First Name: Scott
Default Triton base
i am working on a offset router base and want it to fit a Triton (among others) of which I do own. I have the 4 hole mounting hole pattern but need the orientation of the handle. Can anyone help? Do the handles orient parallel with the square hole pattern or at 45 degrees. make sense? Or if some one could please take a picture of the base looking up to see the handles that would work.
thank you
scott
scottgrove is offline
post #2 of 3 (permalink) Old 09-10-2017, 11:46 AM
MEBCWD's Avatar
Steve look at the 4th picture down on both these links and you will see it all depends on which model you are talking about.
https://www.amazon.com/Triton-MOF001...uter+baseplate
https://www.amazon.com/Triton-TRA001...uter+baseplate
MEBCWD is offline
post #3 of 3 (permalink) Old 09-10-2017, 05:19 PM Thread Starter
First Name: Scott
perfect, why didn't i think of that.
much appreciated
Heavy duty mobile base curlie4 Tools and Woodworking 13 02-27-2017 07:21 PM
DW618 DIY Sub Base Modification rpludwig General Routing 2 02-08-2014 12:12 PM
Triton Routers PeterGee Portable Routing 38 01-15-2013 08:32 PM
Important information regarding TRITON harrysin Lobby 1 01-05-2010 08:08 PM
