Template Material - Router Forums
post #1 of 11 (permalink) Old 05-10-2005, 06:04 AM Thread Starter
Question Template Material
I've made small router templates in the past out of 1/4" tempered hard board (Masonite). I looked for a larger 2' X 4' pc at Lowes this morning only to find out they don't have any Masonite.
Has anyone used any alternative material for templates? 1/4" Birch plywood?
Thanks in advance
--Dave
CCRT is offline
post #2 of 11 (permalink) Old 05-10-2005, 08:55 AM
First Name: jerry
I've seen tempered hardboard (masonite is a brand name) at both lowes & home depot. Many people also use baltic birch plywood,in a pinch you can use whatever you have available.
regards
jerry
jerrymayfield is offline
post #3 of 11 (permalink) Old 05-10-2005, 09:09 AM
Thanks in advance
--Dave
Hi Dave,
I've used just about anything I had as scrap to make templates. Anything from 1/4" to 3/4" works fine. Masonite or plywood, they both work fine. Just select the type of bit to fit the situation. Pattern bits vs. Flush Trim bits. The best advice I can offer is that you make sure your template is sanded smoothly with no irragularities because they will show through on your completed project and use a good quality double sided sticky tape to make sure nothing moves during the cutting process. Good luck.
Bill
Billwolley is offline
post #4 of 11 (permalink) Old 05-10-2005, 11:03 AM
I use 1/4" or 5/16" MDF for all templates I make.
It has the advantage of being able to be filed smooth to ensure a good finish when you route the workpiece.
Dewy is offline
post #5 of 11 (permalink) Old 07-09-2005, 07:05 AM
Thanks in advance
--Dave
The majority of my templates are made from 12mm MDF and if I have the material handy I usually laminate both sides. I also use 9mm MDF laminated anything less than 9mm will cause problems with the depth of my template guide. Keeping in mind I use the template guides regularly
Tom
template tom is offline
post #6 of 11 (permalink) Old 08-11-2005, 12:28 AM
I think 1/4" plywood works fine. I recently used a 1/4" plywood template to route 100 toy swords. Still got the template without any gouges or anything.
woodshopwilly is offline
post #7 of 11 (permalink) Old 08-11-2005, 12:35 AM
Another possibility is using 1/4" Plexiglas. It does have the added advantage of being clear, and for some jigs that is a real plus.
post #8 of 11 (permalink) Old 02-24-2010, 08:29 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Did you notice Levon that you answered a 2005 post! Hopefully by now that member is a fully fledged routologist!
Harry
harrysin is offline
post #9 of 11 (permalink) Old 02-24-2010, 08:32 AM
levon's Avatar
First Name: levon
lol, im not sure where i got that one from. guess the mind is going now, the eyes and steady hands just led the way lol.
im glad you brought that up, at least i had a laugh, even if it was at myself.
levon
levon is offline
post #10 of 11 (permalink) Old 03-04-2010, 08:05 PM
Oxbox's Avatar
First Name: Peter
I've used 1/4 MDF for templates and found when routing Hardwood (Aussie Jarrah) the edge of the template mushroomed over and began developing "potholes" causing my work to end up rough and not quite the right shape. I know I will avoid using MDF in the future. Perhaps just one cut would be OK but multiple cuts I would not recomend.
Oxbox is offline
template routing 2.5" thick material Mcgyver1 Table-mounted Routing 11 09-07-2009 11:31 AM
Half Blind Router Template Question stevek433 Guide Bushings and Templates 5 02-06-2009 08:23 AM
Template Routing FlyFAmerica Portable Routing 11 12-21-2008 12:36 PM
Hitachi M12V template guides? vwmowery General Routing 6 08-31-2006 11:51 PM
Template, how to make? smacmullin Jigs and Fixtures 2 11-08-2005 04:52 PM
