adding a juice groove to a cutting board - Router Forums
 5Likes
  • 1 Post By JFPNCM
  • 1 Post By Stick486
  • 1 Post By rrrun
  • 2 Post By subtleaccents
post #1 of 7 (permalink) Old 09-28-2017, 09:51 AM Thread Starter
JFPNCM's Avatar
First Name: Jon
Default adding a juice groove to a cutting board
I'm considering adding a juice groove to a new end grain cutting board and would appreciate comments on the following:
1) The board is a checkerboard design with maple, cherry, walnut and oak pieces each with a surface area of about 1" x 2". Should I be concerned about blow out as the bit passes across these pieces?
2) Is there a recommended bit and depth?
3) The overall dimensions are 14 x16". On that basis how far in from the edges would you place the groove?
Thanks in advance.
Admin likes this.
Jon
JFPNCM is online now
post #2 of 7 (permalink) Old 09-28-2017, 11:13 AM
Thanks in advance.
1... no...
2... ½~¾''...
3.. bowl or ball bit..
Stick486 is offline
post #3 of 7 (permalink) Old 09-28-2017, 03:18 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
@Stick486
Thanks Stick. Very helpful as always.
Hope the snows come o you soon. 2' on Mt hood and it looks GREAT.
Jon
post #4 of 7 (permalink) Old 09-28-2017, 04:27 PM
@Stick486
yur welcome..
snows showed up at the end of July...
Herb Stoops likes this.
Stick486 is offline
post #5 of 7 (permalink) Old 09-29-2017, 09:19 AM
rrrun's Avatar
First Name: Henry
1... no...
2... ½~¾''...
What he said.
I would do a 1/2" ball nose, 3/4" from the edge. Note you're losing 2-1/2" of work space in each direction with this process.
Relieve the edges of the groove with your sander, and you're done!
JFPNCM likes this.
Henry
Santa Clarita, CA
www.MowryJournal.com
rrrun is offline
post #6 of 7 (permalink) Old 09-29-2017, 10:48 AM Thread Starter
JFPNCM's Avatar
First Name: Jon
@rrrun
Appreciate the added suggestion.
Based on the layout of the board and approx. 1' x 2" dimension of each piece that grove should work very well. I'll post the finished photos later.
Jon
post #7 of 7 (permalink) Old 09-30-2017, 11:33 PM
First Name: JT (Jim)
This HDPE cutting board is 12" x 16" and I used a 3/4" ball nose bit cutting at 1/4" depth.
TenGees and honesttjohn like this.
subtleaccents is offline
B-52 Tail shaped Walnut cutting board difalkner Show N' Tell 11 09-21-2017 07:56 AM
Juice groove in curved cutting board Dean Cruse Portable Routing 11 12-20-2016 04:10 PM
He's Back!!!! Cutting Board Questions vchiarelli Tools and Woodworking 28 12-01-2016 12:00 PM
Cutting board and dovetail joinery rzaccone Table-mounted Routing 2 05-12-2006 10:14 AM
Cutting Board woody Show N' Tell 3 04-02-2006 03:32 PM
