Collet extension for a 1/4 inch router - Router Forums
 4Likes
  • 3 Post By Stick486
  • 1 Post By Cherryville Chuck
post #1 of 4 (permalink) Old 10-01-2017, 11:52 AM Thread Starter
Country: Ireland
First Name: Aiden
Default Collet extension for a 1/4 inch router
Hi there, this is my first posting. I am looking for an extension to my 1/4 inch router collet to enable me to follow the plans for a routed bowl that I come across. Any advice appreciated.
WoodworkA is offline
post #2 of 4 (permalink) Old 10-01-2017, 12:20 PM
welcome Aiden...
the ¼'' shank extensions available here are for CNC and not for hand held routers...
free hand router extensions are ½'' shank... it's all about safety..
however, on your side of the pond, Trend may have what you need/can use...
https://www.trenddirectuk.com/trend-...llet-extension
neville9999, Semipro and hawkeye10 like this.
Stick486 is offline
post #3 of 4 (permalink) Old 10-01-2017, 01:15 PM
Hi Aiden and welcome. A 1/4" extension would be very fragile. I've never seen one here because of that. You may be able to find longer bits though but probably only in small diameters for the same reason. I've had one or two 1/4 bits snap off over the years.
neville9999 likes this.
post #4 of 4 (permalink) Old 10-02-2017, 03:44 AM Thread Starter
Country: Ireland
First Name: Aiden
Thank you for your replies Chuck & Stick. I appreciate the safety advice. Trend direct do have the collet extension so I might get that but be very aware of your advice re: safety and snapping. Thanks again.
Aiden.
Router Collet Extension Marco Router Bits - Types and Usage 7 08-09-2016 11:02 AM
Freud FT2200 1/4 collet - help. Maverick81 Freud 1 09-28-2013 03:44 PM
Problem with installing 1/2 inch bits in new Triton 2 1/4 router roofner General Routing 14 06-04-2013 01:54 AM
Broken Router Collet deanr Table-mounted Routing 12 10-26-2012 12:52 PM
1/2 inch and 1/4 inch collet? JohnsoGreg2012 General Routing 6 01-22-2012 12:45 AM
