Triton or Bosch router. - Router Forums
 12Likes
post #1 of 13 (permalink) Old 10-07-2017, 07:01 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Triton or Bosch router.
It seems to me that the Triton routers are becoming more and more popular here on this forum. Do y'all think they will take over what I believe is the number one spot Bosch? It appears to me that Triton is making some pretty good tools all around. Their track saw comes to mine.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 13 (permalink) Old 10-07-2017, 08:30 AM
you trying to start a fight...
compare Customer Services, repair service centers and how many vendors there are...
thomas1389 and ejw1234567890 like this.
Stick486 is offline
post #3 of 13 (permalink) Old 10-07-2017, 08:59 AM Thread Starter
hawkeye10's Avatar
First Name: Don
I went to the dentist yesterday I told them I was no John Wayne so no I don't want to start a fight. I just wanted to see what people thought. I don't have either one of those routers.
post #4 of 13 (permalink) Old 10-07-2017, 09:56 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I've always considered the Triton routers to be great in a table but not ideal for hand held use. I have a TRA001 in the table but use Makita's for everything else. The only Bosch router that I have owned was a GOF-1300-ACE in 2000 and was not happy with it, there was play in the pillars.
dirt_dobber likes this.
Harry
harrysin is offline
post #5 of 13 (permalink) Old 10-07-2017, 10:01 AM
MT Stringer's Avatar
+1 What Harry said. Triton in the table, Bosch for hand held use (or table use also). I have both.
MT Stringer is offline
post #6 of 13 (permalink) Old 10-07-2017, 01:01 PM
Harry nailed it for me. Triton TRA001 in the table, Bosch 1617s for hand held use. Bosch Colt for trim and carbing where find control is required. Triton is just too heavy for me to control hand held. The switch intercange is a good thing, and also a little annoying sometimes. You need pretty good access below the table to lock the height and manipulate the safety on/off switch. Bosch plunge base for both the Colt and 1617s is very smooth. The Triton has a particularly nice dust collection setup. My Triton is mounted on a Woodpecker plate. A lot thicker than other brands, and it has twist lock inserts, which are much nicer than unscrewing it each time you want to change it. Harry's the one who inspired my getting the Triton, one of the best purchases ever.
I also just bought the Triton track saw, which is pretty good, at least I'm happy with it. Works best if you score the material first, then make the cutting pass. Cut good side down, consider using painter's tape on the cut line.
harrysin and Danman1957 like this.
DesertRatTom is online now
post #7 of 13 (permalink) Old 10-08-2017, 10:14 AM
This is an example of whatever you are most comfortable with being the right choice for you.
jw2170, billyjim, Gaffboat and 1 others like this.
post #8 of 13 (permalink) Old 10-08-2017, 12:37 PM
Terry Q's Avatar
Most of the contributors who buy a Triton buy it for under the table use since most comments are itís too heavy for hand held use.
The other things I noticed about everyone who has commented on using the triton under a table is that you have to constantly reach under the table to get it to work. The spring has to be removed/modified to get it to work. You have to reach under to unlock it to adjust the bit height, causing the motor to shift/drop, requiring you to come up with a work around. You have to reach under the table to turn it on, since it has some kind of safety switch; that or coming up with a work-a-round to keep it on. Do you have to reach under the table to remove the bit?
It seems like most are buying the triton so they donít have to buy a router lift, but from what I can tell, the Triton is a poor substitution for a real router lift. Might save a few dollars, but once you use a real router lift you wonít like your triton any longer, then you have a router that isnít good for hand held use or desirable to use table mounted. I know you can do better then a Triton.
RainMan 2.0 likes this.
Terry Q is offline
post #9 of 13 (permalink) Old 10-09-2017, 03:48 AM
Terry, removing the TRA-001 plunge spring is very easy and takes less than a minute. As with all routers when you set the bit height you do so moving the bit up and there is no drift. When you raise the router all the way up the shaft locks so you can change bits with one wrench. With a Musclechuck installed you do not have to raise the router all the way up and lock the shaft. The Triton is very popular with forum members and a good choice.
Using the Triton or any lift means a lot of cranking the handle. For me it is much easier and faster to pop the router out of the table for bit changes/adjustments.
jw2170 likes this.
post #10 of 13 (permalink) Old 10-09-2017, 04:18 AM
harrysin's Avatar
First Name: Harry
I'm surprised Mike that you prefer to lift the router out of the table for bit change. Firstly, the Triton can be raised for quick, simple bit change and any other router with a MUSCLECHUCK fitted can also have the bits changed from above.
I doubt that there is a faster router lift than this one that I made from an idea from the late Israeli member NIKI.
Name:	Niki-lift explanation.jpg
jw2170 likes this.
Harry
harrysin is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
simple router table - attach vacuum hose to router box, or use Bosch dust adapter? achoox4 Table-mounted Routing 7 07-07-2014 04:01 AM
Bosch router table question Florida Jim Table-mounted Routing 4 12-16-2010 12:04 PM
Bosch Router Table larryc Table-mounted Routing 1 07-06-2008 12:31 PM
