1/4" collett pulling out of router - Router Forums
post #1 of 5 (permalink) Old 05-16-2005, 03:53 AM Thread Starter
Default 1/4" collett pulling out of router
Hi. I am new to the forum and having conducted unsuccessful searches have decided to place my question here. I have a Triton 1/2" router with a 1/4" collett. On a number of occasions I have had either the whole 1/4" collett pull out of the router, or have had the cutter pull out of the 1/4" collett. The router at the time is being used on hardwood at the highest or second highest speed. Has occurred with both dovetail and straight cutters. Any ideas?
Ausie is offline
post #2 of 5 (permalink) Old 05-16-2005, 07:33 AM
kp91's Avatar
First Name: Doug
Couple of things you should check:
Cleanliness of collets- any debris or burrs could prevent you from tightening down evenly on your bit or collets.
Diameter of bits- some lower cost bits have undersized shanks that are smaller diameters than 1/4 inch. These can prevent collets from tightening properly because they can't go that small.
Use two wrenches to tighten- I always feel more secure tightening a bit with two wrenches (if it is an option) than the spindle lock.
Don't bottom out your bits- Leave a little gap under your bits when tightening them down so the collet and bits can be pulled into the spindle and compressed.
Broken collet- After a few years with my first Porter Cable router, the collet developed a crack and lost its usefullness. Less than $10 to replace.
Don't rule out a manufacturer defect- If you try everything else, contact the manufacturer. Quality manufacturers should be more than happy to help you out.
***SAFETY FIRST*** if you are using that router in a table- when a bit comes loose it comes up out of a table. NEVER put your hand over the path of a bit when plowing a groove or dado.
Just a couple of thoughts, hope they help!
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 5 (permalink) Old 05-16-2005, 08:11 AM
delroy33's Avatar
First Name: roy
With a micrometer measure the outside diameter of the bushing with a 1/4" shank in the bushing. The diameter should be .500 anything under will not be held evenly in the 1/2" router collet. The same is true for the 1/4" I.D. of the bushing (.251) I.D. It can be checked by useing guage pins in .001 increments.
The router collet I.D. should check out at about .501. A collets holding and runout are effected by the fit of the parts used.
roy
start square, finish square
delroy33 is offline
post #4 of 5 (permalink) Old 05-17-2005, 06:19 AM Thread Starter
Thanks for the replies. Both the 1/2" and 1/4" colletts are new. Replaced about a week ago to try and resolve the problem. At least they were replaced under warranty. won't be able to check the measurements until tomorrow. Will keep you informed.
Bob
Ausie is offline
post #5 of 5 (permalink) Old 05-18-2005, 05:28 AM Thread Starter
I have just measured the shank on two 1/4" CMT cutters. They each measured 0.2485" diameter. The inside diameter of the 1/4" collet is 0.245" while the outside is 0.4985. The inside diameter of the 1/2" collett is 0.490 and when tightened up this closes to 0.481". More than enough to clamp the 1/4" collet. To tighten the 1/2" collet to 0.481" I really had to apply some pressure. I am starting to wonder if I have not been applying enough pressure. I was always lead to believe that one should just "snug" the collet around the shank. I will have to wait until the weekend to do some more tests. Will post the results.
Ausie is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
