Spiral bit went deep - Router Forums
 7Likes
post #1 of 17 (permalink) Old 10-19-2017, 03:12 PM Thread Starter
First Name: Jamie
Default Spiral bit went deep
I am building a tool box and needed to rout 1/4" by 1/4" deep grooves. The 1/4" up spiral bit loosened and began to drill itself deeper into the groove. I realized in time to save it from going right through the board.
There is only about a 1/16" left. The hole will be hidden by the front panel spline. How would you fill the hole to strengthen it? White glue and sawdust? Epoxy?
Thanks,
Jamie.
jemangin is offline
post #2 of 17 (permalink) Old 10-19-2017, 03:25 PM
rock hard putty or synthetic wood filler...
post #3 of 17 (permalink) Old 10-19-2017, 04:57 PM
First Name: Richard
I agree with Stick.
Shop guy is offline
post #4 of 17 (permalink) Old 10-19-2017, 06:05 PM
I don't if Stick meant Durham' Rock Hard or not but it's the one I use. It's often harder than the wood you put it on. It's a dry powder that you mix with water and you have from 30 minutes to an hour to use it up. The powder never goes bad so that is another selling point and it's relatively cheap too.
Danman1957 likes this.
post #5 of 17 (permalink) Old 10-19-2017, 06:15 PM
Durham's Rock Hard it is...
post #6 of 17 (permalink) Old 10-19-2017, 07:57 PM
pal
pal's Avatar
First Name: Harold
Builders Bog looks and works the same as Selleys Plasti-Bond
Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning.
Albert Einstein
pal is offline
post #7 of 17 (permalink) Old 10-19-2017, 08:25 PM
I don't
say what!?!?!?!?
post #8 of 17 (permalink) Old 10-20-2017, 12:05 AM
jj777746's Avatar
say what!?!?!?!?
I'm sure Charles left out "know" (I don't "know" if Stick meant--).The weird thing is I didn't realise the word know was missing until I saw Stick's "I don't"post.Anyone else see the missing word at first??
RÖENTGEEP likes this.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #9 of 17 (permalink) Old 10-20-2017, 06:32 AM
hawkeye10's Avatar
First Name: Don
A piece of 1/4" dowel. Either cut a really short length and drive it in the hole with some glue or fill the hole with the dowel and redrill it.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 17 (permalink) Old 10-20-2017, 08:31 AM
First Name: Gary
I would re route to an even depth, then glue a strip of wood, and then re rout the groove to the correct depth.
gmercer_48083 is online now
Straight bit vs. spiral bit JimofSC General Routing 14 06-29-2015 05:18 PM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
Ruined my 1/2" spiral bit. RJM60 Guide Bushings and Templates 2 09-13-2010 05:51 PM
Endmill vs Spiral bit Timberwerkz Router Bits - Types and Usage 1 06-22-2010 11:31 PM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
