Rounding off an internal hole - Router Forums
 10Likes
post #1 of 13 (permalink) Old 10-23-2017, 12:01 PM Thread Starter
jazzzbo's Avatar
Question Rounding off an internal hole
I made a table saw sled yesterday. I used a drill to make a couple of holes and a jig saw to join them to make a couple of hand holes. Then I wanted to use my brand new router for the first time to 'round off' the holes.
Needless to say, after trying several ideas, I finished the larger-than-wanted holes with a rasp.
What would be the best technique for rounding off internal holes, please?
jazzzbo is offline
post #2 of 13 (permalink) Old 10-23-2017, 12:17 PM
DonkeyHody's Avatar
First Name: Andy
I use a round-over bit with bearing pilot. The radius of the bit must be less than 1/2 the thickness of the material, or the bearing won't ride on the original surface when you round over the second side. Adjust the depth of the bit so that you get a round over without a ledge at the top surface. For internal cuts, you'll move the router in a clockwise direction to avoid the bit grabbing.
DonkeyHody is offline
post #3 of 13 (permalink) Old 10-23-2017, 12:18 PM
Gaffboat's Avatar
First Name: Oliver
A round over bit with a bearing should make it a quick and easy job using a hand-held router.
Herb Stoops likes this.
Gaffboat is offline
post #4 of 13 (permalink) Old 10-23-2017, 12:23 PM
Stick486 is offline
post #5 of 13 (permalink) Old 10-23-2017, 12:37 PM
MT Stringer's Avatar
+1 what they said.
Think about it for a minute. If the material is 3/4 inch thick, a 3/8 inch round over bit will make a smooth edge. When run on both sides of the material, it will create a rounded edge because the cutter will meet from the other side. Or just do one side only, your choice.
A 1/4 inch roundover bit will also make a rounded edge that takes off the sharp edge wlhere you cut your opening.
Practice on some scrap. Adjust your cutting depth so the pilot bearing rides against your material, and the cut creates the rounded over edge you are looking for. You might have to adjust the depth up or down to get it right. Then all that is left is some light sanding. Should come out looking good.
BTW, round-over bits get used a lot in the wood shop.
Good luck.
Herb Stoops and gjackson52 like this.
MT Stringer is offline
post #6 of 13 (permalink) Old 10-23-2017, 01:42 PM
Exactly what Andy suggested.
post #7 of 13 (permalink) Old 10-24-2017, 06:42 AM
difalkner's Avatar
First Name: David
+1 to the roundover bit suggestions. That's what I used on mine.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #8 of 13 (permalink) Old 10-24-2017, 07:58 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
As has been mentioned, a round-over bit with a bearing. The template is NOT required, it was still in place from routing the coin tray.
Harry
harrysin is offline
post #9 of 13 (permalink) Old 10-24-2017, 10:37 AM
Ghidrah's Avatar
First Name: Ronald
I had a similar problem some time ago but I didn't have a rnd over bit with the profile or the depth of cut I required, the material I was working was too thin. I found 2 solutions that worked.
1. I drilled a similar hole in a 2nd piece of material then aligned both with a dowel and double sided tape.
2. I have a few non bearing ovolo bits, one with the profile I required, I plunged the bit into the hole to align it then used double sided tape on wood strips to block the router base in place
Ghidrah is offline
post #10 of 13 (permalink) Old 10-24-2017, 03:03 PM
Bushwhacker's Avatar
First Name: David
I just did this yesterday. Had a 1X3 inch slot. I wanted to round the edge over so I used a round over with a bearing and ran scrap wood until I got it like I wanted then ran my piece over it.
Same as everyone else said.
David
When the enemy is in range, so are you.
Bushwhacker is offline
How to make hole in base of router larger? kglade Guide Bushings and Templates 15 05-31-2016 12:16 AM
Advice on Cable Grommet Techniques plunger Starting Off 13 10-03-2015 01:03 AM
Rounding over inside diameter of a hole jschaben General Routing 11 01-03-2011 10:10 PM
Drilling large hole over small hole or vice-versa simplenik Tools and Woodworking 8 06-13-2007 07:57 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 04:29 PM
