Pawn shop score or not score? - Router Forums
 12Likes
post #1 of 21 (permalink) Old 12-08-2017, 10:48 PM Thread Starter
First Name: Randy
Default Pawn shop score or not score?
I think I scored at a pawn shop today. They had a Porter Cable router kit for $69. They had a pair of dial calipers for $22.
I asked if they would take $50 for the router............. facial expressions told me no ........ so I said "how about $50 if I buy the calipers too"? ($22)
So $72 later I walked out with the router+case calipers+case.
The router is the same model Porter Cable router that I recently purchased new for $170. 690LR
Unlike the new router I recently bought, this used one has the case, the plunge base, the standard base and a guide plus both collets. That combo is at least $206 from Amazon.
https://www.amazon.com/PORTER-CABLE-.../dp/B00006411C
The Chinese calipers can probably be purchased new for $30, but I still think I done good overall. Router has signs of use, but sings like a brand new one and it's American made. I suppose that can tell me about how old it is? I know it's been used a fair amount as the cord is in good condition but the plug end has been replaced. Bearings feel good and tight.
Now I can leave one router in my router lift permanently instead of switching back and forth, and I have three bases.......... one "pre-owned" standard base to use and abuse. An identical brand nes base to use on more delicate surfaces because it's plastic base is not scratched up, plus a plunge base and a plastic carrying case with all accessories still in it. Both routers have the 1/4" and 1/2" collets
I don't see the PC 690 being bragged about here a lot, but I like it.
Anyway, felt like a decent deal since the router sounds so nice.
kp91, BrianS, DaninVan and 4 others like this.
ranman is offline
post #2 of 21 (permalink) Old 12-08-2017, 11:08 PM
BrianS's Avatar
First Name: Brian
Sounds like a good deal to me. I have an older PC 690, and am very pleased with it. I have the plunge base, and the D-handle base with it.
Herb Stoops likes this.
Brian
(Origin uncertain)
BrianS is offline
post #3 of 21 (permalink) Old 12-09-2017, 12:52 AM Thread Starter
First Name: Randy
I had a friend who owned 5 of them, so that's why I bought one. There is one funky looking black plate thingy in the kit. I'm assuming it's a guide but don't know what it's for. It has a U shape on one end and holes for the steel rods to mount to the router. That U shaped end of that plate........ is it a pivot for cutting circles?
ranman is offline
post #4 of 21 (permalink) Old 12-09-2017, 05:41 AM
Terry Q's Avatar
I have two porter cable 690 routers. Never had a problem with one, but because itís a fixed speed router you canít use it with larger mass bits.
I once tried flush trimming an edge on a thick table top. Went out to buy a flush trim bit that was longer then 1 inch. Ended up with a 3/4 round, 1 1/2 long bit. Chucked it up, turned it on, and chewed the heck out of my table top because I couldnít control the router. I made the top a little smaller and started over with a variable speed router and had no problem controlling the router. Learned an important lesson that day.
And yes, that is a great score.
Terry Q is offline
post #5 of 21 (permalink) Old 12-09-2017, 05:50 AM
vchiarelli's Avatar
First Name: Vince
I've had a PC690 for a number of years and always liked it. Sounds like you got a good deal.
That U-shaped thing sounds like you're describing an edge guide. If you post a picture we can confirm.
vchiarelli is offline
post #6 of 21 (permalink) Old 12-09-2017, 08:25 AM
Garyk's Avatar
First Name: Gary
690 (USA model) is a good general use router. Doesn't have all of the bells & whistles of the new routers but it's solid. Mine is at least 20 years old and still works just fine. The original base is wearing a bit but they are available for $50/60 online. $73 @ Home Depot. Have had mine in a router table and it works for light duty use. Never used the plunge base that came with it, I use my 1617 Bosch for that.
Garyk is offline
post #7 of 21 (permalink) Old 12-09-2017, 09:04 AM
Gene Howe's Avatar
First Name: Gene
No worries. You scored.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #8 of 21 (permalink) Old 12-09-2017, 10:00 AM
That was a great score. You're right about the actual value of the caliper but they are an invaluable tool in the shop. I keep one handy that reads in fractions and millimeters. I started a thread once to see how many use one and how many uses they found for it but I don't remember the thread going very far so I'm not sure if that many members use them.
The biggest issue with my PC tools has been bearings. Upon replacing them I found PC used some of the cheapest they could source. Stick says replace them with a ceramic one if they go and you'll never have to worry about the bearing again. If any of mine go again that's what I'll do.
Danman1957 and jj777746 like this.
post #9 of 21 (permalink) Old 12-09-2017, 11:28 AM Thread Starter
First Name: Randy
They had two pairs of 6" calipers. One had a ever so slight misalignment so I got the 'good one' It goes to zero consistently ad feels very smooth.
I have a dial indicator also. I used that to check the flatness of the top insert plate of the lift I'm making and to see if the shaft is perfectly square to the plate.
The plate is off .017 towards one corner about 6 inches out from the shaft.... that's about the thickness of 5 sheets of paper. On a left to right plane through the center of the plate, it was almost perfect.
My old calipers (Chines also) went bad after 5 years of abuse........ they were used when I bough them also. They are really a must have tool.
A wood flooring company told about using calipers to tell when wood flooring is acclimated to a home's environment. They said deliver the wood to the home and pull a few boards from the boxes. Next, measure the board width in a handful of places and mark them with blue tape. Wait a week, then come back and re-measure the same places as before. Then wait another week and repeat. If the board width measurements from week 1 and week 2 are the same, it's ready to nail down. Neat idea.
ranman is offline
post #10 of 21 (permalink) Old 12-09-2017, 11:46 AM Thread Starter
First Name: Randy
That's it. Thanks.
ranman is offline
I need a new shop. JOAT Lobby 29 11-13-2017 01:01 PM
Almost Finished My Wood Shop stan2602 Workshop Showroom 6 08-31-2013 11:21 AM
My shop -- Finally! rcp612 Workshop Showroom 13 07-18-2012 09:01 AM
New shop...where to put router...need two tables? Froglips New Member Introductions 1 06-12-2012 12:59 AM
Shop Organization Marco Tools and Woodworking 8 10-07-2011 06:57 AM
